Power steering pump making noise, safe to drive? #112205
08/29/08 07:52 PM
08/29/08 07:52 PM
Nebraska
71blueduster Offline OP
super street
super street
Nebraska
My power steering pump on my 99 Dakota started making noise yesterday. A rattling sound when the engine is running. Kind of like a bearing or something going out. Its making the noise, but the pulley is still solid and doesn't have any play in it, the power steering still works fine.
I was planning on making a 100 mile trip, so would it be safe to drive it or should I not risk it breaking down on me? The shops I called were all filled up today, and I don't have all the tools to fix it myself.
Re: Power steering pump making noise, safe to drive? [Re: 71blueduster] #112206
08/29/08 09:03 PM
08/29/08 09:03 PM
Anywhere the British Secret Se...
Moonraker Offline
Moonraker  Offline
Maybe, maybe not mechanical things like bearings/bushings can go out slow or go boom . Being that its a serpentine belt if it does crap out theres no way to by pass like you could with the old V-belt setup . Check your fluid level if you havent already, could be low . If it were me and I had no other way.... ...I'd drive it.
Re: Power steering pump making noise, safe to drive? [Re: 71blueduster] #112207
08/29/08 09:03 PM
08/29/08 09:03 PM
The PS pump in my former 83 cordoba had a slow leak & when it got to a point it would emit a low pitched growl & that was my cue to top her off.
Re: Power steering pump making noise, safe to drive? [Re: RapidRobert] #112208
08/29/08 09:21 PM
08/29/08 09:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you sure it's the pump and not the idler pulley?
Re: Power steering pump making noise, safe to drive? [Re: stumpy] #112209
08/30/08 01:13 AM
08/30/08 01:13 AM
md
mopars4ever Online content
mopars4ever  Online Content
md
I just replaced the idler pulley on my 97 ram. That thing was making a heck of loud bearing noise. Check the water pump too they can make that noise. Mike
Re: Power steering pump making noise, safe to drive? [Re: mopars4ever] #112210
08/30/08 01:47 AM
08/30/08 01:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If it was the old v-belt style, I'd say pop off the belt and go, while 'enjoying' the added firmness of a dead PS system. But with the serpentine setup, if something seizes and you pop a belt in the middle of nowhere, you are SOL.
