STOCK VALVE COVERS CLEAR ROLLER ROCKERS? #1121306
11/25/11 09:07 PM
11/25/11 09:07 PM
central ohio
mopar rookie Offline OP
central ohio
I'm gonna start collecting parts for my engine build. If I run Harland Sharp roller rockers will they clear the stock valve covers? My motor will be a maxwedge clone and want the stock look. Also has anyone tried the repop AMD valve covers yet. Thanks
Re: STOCK VALVE COVERS CLEAR ROLLER ROCKERS? [Re: mopar rookie] #1121307
11/25/11 09:42 PM
11/25/11 09:42 PM
Idaho
LaRoy Engines Offline
Idaho
I had to radius the outside corners of the end rockers on the pushrod ends to keep them from hitting the stock valve covers.
Re: STOCK VALVE COVERS CLEAR ROLLER ROCKERS? [Re: mopar rookie] #1121308
11/25/11 10:37 PM
11/25/11 10:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I had to gut the baffles on my 70 factory BB valve covers to clear my 1.6 roller rockers
Re: STOCK VALVE COVERS CLEAR ROLLER ROCKERS? [Re: DAYCLONA] #1121309
11/26/11 01:03 AM
11/26/11 01:03 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Couldn't someone fabricate a spacer plate of appropriate thickness to space the stock valve cover up enough to clear? Essentially, the plate would look like the valve cover gasket, only 3/8-1/2" thick?
Don't be the exception.
Re: STOCK VALVE COVERS CLEAR ROLLER ROCKERS? [Re: Supercuda] #1121310
11/26/11 01:53 AM
11/26/11 01:53 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've thought of the spacer plate, too; maybe I can get some cut. Let me know if you're interested. If there's a market for them, so much the better (and cheaper).
On my Eddy-head, HS 1.6 roller/stock cover motor, I had to chamfer the outermost corners of the rocker shaft hold-downs, and dimple the baffles with a ball-peen, using the thicker cork gaskets.
Re: STOCK VALVE COVERS CLEAR ROLLER ROCKERS? [Re: topside] #1121311
11/26/11 04:01 AM
11/26/11 04:01 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
IIRC, the old MP tall chrome valve cover fit many roller rocker applications.
This is Troy Bray's old Duster he built that recently was on Pinks with the new owner...
