BB Valve Cover Gaskets 1What do you use ? #1121217
11/25/11 06:34 PM
11/25/11 06:34 PM
Gateway to the West.
hemi_harvester Offline OP
Guys over the years I have tried all kinds of gasket materials, fastners and sealents to keep my vavle covers tight and to not leak I have not had much luck..SO what gaskets etc do you use,...Its time to replace them again on my engine.
There comes a time in life, when you walk away from all the drama & people who create it. You surround yourself with people who make you laugh, forget the bad, and focus on the good.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: hemi_harvester] #1121218
11/25/11 07:33 PM
11/25/11 07:33 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
any quality brand gasket works, i've many different brands over the years. with good prep, and good sealant (i use orange silicone) and being careful to resist the urge to over tighten any good gasket will work even old fashion cork ones!
Re: BB Valve Cover Gaskets 1What do you use ? [Re: hemi_harvester] #1121219
11/25/11 07:40 PM
11/25/11 07:40 PM
Kirkland, Washington
Pacnorthcuda Offline
I've had the best success with the Fel-Pro black rubber ones. I torque them down to about 50-60 inch pounds repeatedly over the course of the first 10 or so engine runs--eventually they firm up nicely and seal real well.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: Pacnorthcuda] #1121220
11/25/11 07:45 PM
11/25/11 07:45 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
yep, i think that's what i have one there now..............
Re: BB Valve Cover Gaskets 1What do you use ? [Re: mikemee1331] #1121221
11/25/11 08:51 PM
11/25/11 08:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had good luck with the FelPro cork gaskets; I glue them to the covers and then smear a little grease at the head side. Double-check the fasteners after a week. Make sure your covers are straight, of course. On a car with the HP exhaust manifolds, I've found that they get baked pretty hard after a couple of years, so I keep an eye on them but they still seal. No problems so far with Maxie exhaust or cars with headers.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: topside] #1121222
11/25/11 10:26 PM
11/25/11 10:26 PM
IN
ahy Offline
ahy  Offline
IN
Felpro rubber/cork has worked best for me.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: ahy] #1121223
11/25/11 10:32 PM
11/25/11 10:32 PM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
mr gasket rubber cork work fine and are affordable. i currently use the moroso blue thats metal reinforced. i relly think there going to last for ever. had the covers on and off several times and they still look as new as the day i put them on.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: Deepockets] #1121224
11/25/11 11:07 PM
11/25/11 11:07 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
none
I dont have BB anymore..
I am truckless..
Re: BB Valve Cover Gaskets 1What do you use ? [Re: 340SHORTY] #1121225
11/25/11 11:40 PM
11/25/11 11:40 PM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Moroso blue or Fitzgerald w/metal core(still in biz?). Much better than all the others and worth the cost.
Leave the gun.......take the Cannoli's....Mike
Re: BB Valve Cover Gaskets 1What do you use ? [Re: mike s] #1121226
11/26/11 09:16 AM
11/26/11 09:16 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run the Mr Gasket Ultras.Mine have been off to check the valves and still seal.Even with the MP aluminum covers they seal.Run them on all the cars.Rocky
Chrysler Firepower
Re: BB Valve Cover Gaskets 1What do you use ? [Re: topside] #1121227
11/26/11 10:30 AM
11/26/11 10:30 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
I've had good luck with the FelPro cork gaskets; On a car with the HP exhaust manifolds, I've found that they get baked pretty hard after a couple of years
That was always my problem...they'd get cooked and crack.
I've been running with old police package exhaust manifold gaskets on my daily driver for the past 4 years or so and that solved my problems (they have extra material that extends upward and acts as a heat sheild)
Maybe give them a try...my valve cover gaskets are just the Felpro cork ones too.
Re: BB Valve Cover Gaskets 1What do you use ? [Re: mike s] #1121228
11/26/11 01:38 PM
11/26/11 01:38 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
These are the only ones that will stand up the heat and not leak for years.....
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: BB Valve Cover Gaskets 1What do you use ? [Re: HemiRick] #1121229
11/27/11 11:47 AM
11/27/11 11:47 AM
Orange Park, FL
MRHWS Offline
MRHWS  Offline
Orange Park, FL
Do the Moroso gaskets work on stock heads and covers? I tried the Felpro 1612s(rubber over fiber) and leak at #7 somewhere. Looks like the leak is between head and gasket, dry between cover and gasket.
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: BB Valve Cover Gaskets 1What do you use ? [Re: hemi_harvester] #1121230
11/27/11 11:59 AM
11/27/11 11:59 AM
CHRGR69 Offline
CHRGR69  Offline
Mopar red rubber. RTV it to the valve covers over night. Makes install so much neater and easier.
Grandma always said I had "hands of gold"!
Re: BB Valve Cover Gaskets 1What do you use ? [Re: MRHWS] #1121231
11/27/11 12:03 PM
11/27/11 12:03 PM
Cleveland, Ohio
BB73Challenger Offline
Cleveland, Ohio
I think like was said earlier a good straight cover is more important than the gasket.
On my aluminum head/aluminum cover I'm just using cork that I had applied a light coat of grease to both sides for placement and have been dry as a bone so far.
I have even had the covers on and off a few times all ready due to the solid cam I run to watch/set lash
My brothers small block has some cheapy chrome jobs and we can't get them to stop leaking after MANY gaskets and goo's.
