thurst spacer #1120580
11/24/11 02:01 PM
11/24/11 02:01 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
im installing a 489 sure grip,there is a disc like thing in the center of the axel splines, is that the thurst spacer?if not where should it be located,the disc does not look like the thurst spacer in year one cat.
Re: thurst spacer [Re: 70sate] #1120581
11/24/11 03:59 PM
11/24/11 03:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The cone-type SG unit usually found in the 489 has a one-piece thrust block, the earlier clutch-type SG has the two-piece thrust buttons.
Re: thurst spacer [Re: John_Kunkel] #1120582
11/24/11 04:28 PM
11/24/11 04:28 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
where is it located? what does it look like;how can i find out witch one i have?thx.
Re: thurst spacer [Re: 70sate] #1120583
11/24/11 05:48 PM
11/24/11 05:48 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Re: thurst spacer [Re: MoparforLife] #1120584
11/24/11 06:30 PM
11/24/11 06:30 PM
nesbit,ms.
70sate Offline OP
70sate  Offline OP
nesbit,ms.
thx.and found good info on discussionn forums,identifid it as later mod,cone type,all looks ok,saw thrust spacers in year one cat,did'nt know what the were
Re: thurst spacer [Re: 70sate] #1120585
11/25/11 12:57 AM
11/25/11 12:57 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Sounds like the shim one installs in a used up cone unit to eek a little more life out of it because they are technically not rebuildable. Do yourself a favor and epoxy a couple magnets below the oil level off to the sides of the ring gear to catch the metal chips that POS is going to make everytime you take a corner .
Re: thurst spacer [Re: JohnRR] #1120586
11/25/11 02:00 AM
11/25/11 02:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You will need the thrust spacer in there to set axle end play on a stock setup. Or you could install the greeen bearings on the axles and then you can throw the thrust spacer's away. Ron
