Re: thurst spacer
[Re: 70sate]
#1120581
11/24/11 03:59 PM
11/24/11 03:59 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The cone-type SG unit usually found in the 489 has a one-piece thrust block, the earlier clutch-type SG has the two-piece thrust buttons.
Re: thurst spacer
[Re: 70sate]
#1120585
11/25/11 12:57 AM
11/25/11 12:57 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
im installing a 489 sure grip,there is a disc like thing in the center of the axel splines, is that the thurst spacer?if not where should it be located,the disc does not look like the thurst spacer in year one cat.
Sounds like the shim one installs in a used up cone unit to eek a little more life out of it because they are technically not rebuildable. Do yourself a favor and epoxy a couple magnets below the oil level off to the sides of the ring gear to catch the metal chips that POS is going to make everytime you take a corner .
