Re: NOS and 6-pack [Re: Mr.Yuck] #1120063
11/30/11 10:28 AM
11/30/11 10:28 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Something like this.
Re: NOS and 6-pack [Re: Mr.Yuck] #1120064
11/30/11 10:32 AM
11/30/11 10:32 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Oh yea do your self a favor and get a mirco switch to turn it off and on.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NOS and 6-pack [Re: Mr.Yuck] #1120065
11/30/11 10:35 AM
11/30/11 10:35 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes looks like it would work but where are you going to get your jetting maps from?
Re: NOS and 6-pack [Re: 1967dartgt] #1120066
11/30/11 10:44 AM
11/30/11 10:44 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
my what??? lol I guess I'll have to do some reading. Still not sure if I'm going to do it, I guess it will depend on cost.
Re: NOS and 6-pack [Re: Mr.Yuck] #1120067
11/30/11 12:01 PM
11/30/11 12:01 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
If your just going to try to use one fogger per end which I wouldnt do myself why not just use the 40 year old plate kit from holley????? Which I dont think the any longer sell.
I will sell you my old plates cheaper then you can buy two foggers and plumb them. Id almost give the old outdated things away.
Remember a fogger hp is the jet combo x8, and then your on a dual plane intake? Dont the BB have the dividers in the intake like the small block, cant see all being equal.
I cant see how budjet/cheap and nitrous fit in the same picture.
Id consider somthing like a msd window switch since you dont need a controller vs a micro switch..esp since you street drive.
Good luck!
Re: NOS and 6-pack [Re: quick77rt ] #1120068
11/30/11 12:33 PM
11/30/11 12:33 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
my spacers are open. I would think the fogger would mist/distribute the mixture fine??? Not against the plate system. PM the details on what you have...
wonder how it would inter-act w/ the Meth/H2O....
Re: NOS and 6-pack [Re: Mr.Yuck] #1120069
11/30/11 07:50 PM
11/30/11 07:50 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
PM sent..
Re: NOS and 6-pack [Re: quick77rt ] #1120070
11/30/11 09:05 PM
11/30/11 09:05 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
back at ya
Re: NOS and 6-pack [Re: Mr.Yuck] #1120071
12/02/11 06:47 PM
12/02/11 06:47 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Here is my weekend project. Ive a few diff style tips so im gonna test spray them to see the pattern and then determine where to put them depth and angle wise.
Since this is on the open plenum mod man and not a dual plane im gonna run six foggers and find a ratio that works for the center carb jetting as it dumps right into the same open plenum.
I plan to just go very easy and read the plugs and slowly turn it up.
Got the plate from Ben today...he makes awsome parts.
Re: NOS and 6-pack [Re: quick77rt ] #1120072
12/03/11 11:19 AM
12/03/11 11:19 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
why don't you just open up each plenum, that way you could go w/ 3?
Re: NOS and 6-pack [Re: Mr.Yuck] #1120073
12/03/11 01:23 PM
12/03/11 01:23 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Yuck that may work on a oem intake, who knows..the mod man is a simple straight forward single plane with a semi big plemum.
I use the spacers with the dividers for a reason, motor is built for spray so the more the better, but mostly I dont see how things could be as equal with 1 vs 2 no matter how much the tip flows when it comes to each cylinder getting an equal mix.
But I just go by trial and error....go for the single tip and let us know what pops. Bad word, I meant how it runs.
Re: NOS and 6-pack [Re: quick77rt ] #1120074
12/04/11 04:52 AM
12/04/11 04:52 AM
San Diego
formula S Offline
formula S  Offline
San Diego
I did a plate system from NOS and burnt up a couple of pistons due to the poor fuel distrubition of a stock 6-pak the fuel falls out of suspension and never makes it to the cylinder but the nitrous dose
Re: NOS and 6-pack [Re: formula S] #1120075
12/04/11 12:20 PM
12/04/11 12:20 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
How much were you spraying and how much timing were you running?? Do you have a picture of the piston/pistons??
If you can't handle the truth, you're living a lie.......
Re: NOS and 6-pack [Re: formula S] #1120076
12/04/11 01:16 PM
12/04/11 01:16 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Was it a BB or small block? Ive had really good luck with the oem small block intakes and the older holley plate kit, only issue I ever had was an error on my part. (stuck micro switch).
The mod man with the spacers let me go one step further and I lost nothing down low. The oem stopped pulling about 6800, with a 7600 chip it will pull that and seems to want more, but thats the max on this motor.
Re: NOS and 6-pack [Re: Mr.Yuck] #1120077
12/04/11 02:54 PM
12/04/11 02:54 PM
I have a complete Holley six pak unit with hardlines and solenoids not being used. PM if your interested in it
Re: NOS and 6-pack [Re: Big Squeeze] #1120078
12/05/11 01:10 PM
12/05/11 01:10 PM
San Diego
formula S Offline
formula S  Offline
San Diego
No pics on the pistons but the piston had a hole right in the center that you could have droped a golf ball through this was with a 150 shot with 30deg total and this is on a small block
