NOS and 6-pack #1120043
11/23/11 09:50 PM
11/23/11 09:50 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
So I have a six-pack and I have meth/H2O injection under the center carb via a fogger in the 1/2" spacer. If I wanted to hit it with a small 150-200 shot could I use foggers in each of the outboard spacers?
Coming soon!!!!
Re: NOS and 6-pack [Re: Mr.Yuck] #1120044
11/23/11 10:21 PM
11/23/11 10:21 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
Re: NOS and 6-pack [Re: meepmeep70] #1120045
11/24/11 08:48 PM
11/24/11 08:48 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Mechanical or vacume on the outboards?What would you use for a WOT switch?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: NOS and 6-pack [Re: hemi-itis] #1120046
11/24/11 10:59 PM
11/24/11 10:59 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
vaccum.. I'll figure somthing out for the switch, could be run off the Meth injection switch. It's on when the vac drops to 0.
Re: NOS and 6-pack [Re: Mr.Yuck] #1120047
11/24/11 11:45 PM
11/24/11 11:45 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Maybe run the nitrous on a button on the shifter
As for the question, im not sure but good luck
Re: NOS and 6-pack [Re: 69B3GT] #1120048
11/24/11 11:56 PM
11/24/11 11:56 PM
hemi-itis Offline
hemi-itis  Offline
Y'know,I would check with Wayne,username is BIGSQUEEZE.Are you sure the distribution would be equal with injecting just the outboards????????
Re: NOS and 6-pack [Re: Mr.Yuck] #1120049
11/24/11 11:58 PM
11/24/11 11:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
IMHO, I'd go with a direct port set-up, or even a hidden direct port set-up if you'd prefer, the big block 6 pack manifold has enough distribution problems, esp cylinders 6 and 7
You running cast pistons?.....
Re: NOS and 6-pack [Re: DAYCLONA] #1120050
11/25/11 12:03 AM
11/25/11 12:03 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
1 fogger nozzle per plate on a duel plane intake?
Re: NOS and 6-pack [Re: DAYCLONA] #1120051
11/25/11 12:07 AM
11/25/11 12:07 AM
hemi-itis Offline
hemi-itis  Offline
It's been a long time since I played with 6 packs,but I must agree with Dayclona
Re: NOS and 6-pack [Re: DAYCLONA] #1120052
11/25/11 12:17 PM
11/25/11 12:17 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
no Ross pistons... If I did direct I'd hide it under the intake.
Coming soon!!!!
Re: NOS and 6-pack [Re: Mr.Yuck] #1120053
11/29/11 02:24 AM
11/29/11 02:24 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
You guys are making this way too hard, since I have a 1.5 inch spacer on my mod man, 1/2 of it is the plate kit designed and still sold by holley for the end carbs mech or vac.
Im currently working on a full 1.5 inch spacer on the mod man plumbed with more or less 1/2 of a sportsman fogger kit using 4 foggers, one on each side of the end carbs.
I feel the fogger tips are years ahead of the old plate kit with a few holes, on the bench the fogger to really, well fogs, the plate kit likes to mist and drip.
Yes I could probably put newer spray bars, ect in the newer billet spacer but for now its foggers.
I will keep the pro fogger on the controller and this lil deal im gonna try a simple msd window switch and jet it for 100 so just flip a couple switches and ive a 100 shot all the time just for kicks.
I wouldnt be afraid to try this with a 1 inch spacer, 4 foggers, 2 on each end on a oem dual plane as this would be much more eff. then the old plate kit.
I honestly think my plate kit will hang on the wall, I really dont want to pass such old basic non tech parts along when there are so many newer better ways to get it done.
Re: NOS and 6-pack [Re: quick77rt ] #1120054
11/29/11 09:23 AM
11/29/11 09:23 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
so Quick, you just driled out and tapped your spacers for the foggers? I was thinking of doing that too. My primary is drilledand tapped for the meth/H2O, I was thinking I'd do the same for the outboards but w/ a NOS fogger. Just for kicks...
Re: NOS and 6-pack [Re: Mr.Yuck] #1120055
11/29/11 05:57 PM
11/29/11 05:57 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
No thats not what im refering to, I wouldnt trust that plate and look at the link here...
This is when I plumbed my direct port and used this spacer, along with my 1/2 inch plate kit. I let him use my pic.
Im using a spacer as shown in the link, just as the NOS brand kits its only the outter carbs for the foggers esp since on the mod man the ports are directly below.
Also using the plate in the link you can countersink the fogger to the tip depth you want it to be.
Only thing is to watch your butterfly clearence to the tip if your stuck for room.
I will try to post pics tonight so its understood better.
Also working on a plate that has most of the internal plumbing that would take the place of the fuel blocks.
Re: NOS and 6-pack [Re: quick77rt ] #1120056
11/29/11 07:14 PM
11/29/11 07:14 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
I have 1/2" spacers under my carbs much like that picture already. Are you saying get a "plate kit" for the outboards or use foggers in them? Do you have pic of your set-up?
Re: NOS and 6-pack [Re: Mr.Yuck] #1120057
11/30/11 12:15 AM
11/30/11 12:15 AM
Chicago
PurpleBeeper Offline
Chicago
Hey Yuck, I'm no "expert" but I think either outboard spray bar plates or dual foggers on the outboard plates would work fine. Plates have the advantages 1.an engineer sized the solenoids & designed the kit 2.less intake/port restriction when not on the bottle (foggers restict air flow). Foggers work better on the bottle. Track only-foggers Mainly street-plates Just my
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: NOS and 6-pack [Re: PurpleBeeper] #1120058
11/30/11 01:33 AM
11/30/11 01:33 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Well I dont need to be an expert to tell the same noids that came with the org plate kit are the same noids used on the smaller fogger kit x2. Same noids on the 4 banger fogger kit x1 for 4 foggers.
Even different brands of noids is not an issue, as long as it all flows right.
THE SIX PACK PLATE KIT FROM HOLLEY ONLY IS FOR THE OUTBOARDS AND NEVER WERE FOR THE CENTER.
IM not going for the two 40 year old brass bars in each outter plate with a few small holes produces a better mixture then a fogger tip.
Look where the red X is in the pic.....but with a 1.5 inch plate it will be a hair higher. and the black plate kit will be gone.
Re: NOS and 6-pack [Re: quick77rt ] #1120059
11/30/11 01:36 AM
11/30/11 01:36 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Working...Plate and Fogger Kit.
Now ya ready to see the intercooled procharged/six pack/and nitrous setup??
Re: NOS and 6-pack [Re: quick77rt ] #1120060
11/30/11 01:47 AM
11/30/11 01:47 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I plumbed and ran this hidden kit for several years on a oem small block six pack, still old school pig tips, I kept the same 34/36 tips and toned it down equally with big restrictors right at the inlet.
Never an issue, then went to the mini controller.
Only issue ive ever had was a micro switch stick...bad.
I wouldnt use a under the intake kit on a street car, seen many leaks, gummed up lines, and then worse, and I think are getting to be more left in the past...
Re: NOS and 6-pack [Re: quick77rt ] #1120061
11/30/11 09:48 AM
11/30/11 09:48 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Hey yuck nos makes a kit for six pak intakes. Had a set up on a 340 six pak setup worked nice would spray 175hp. It has two plates on the outside carbs and a spacer in the center. It used cheater soleniods and could go to 250hp. Now on a 318 magmun with factory beerbarrel and later a m1 mpi intake I but two fogger nozzles in the air cleaner and would run 175hp on that stockbottom end till 181,000mi when I sold it.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: NOS and 6-pack [Re: 1967dartgt] #1120062
11/30/11 10:16 AM
11/30/11 10:16 AM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks 67, I know they make a kit, however I was trying to save some cash. I think the 6-pack kit is over $650. I already have the spacers..just thought I could piece something together.
