Page 2 of 3 1 2 3
Re: Painting questions... [Re: 73rrak] #1119860
11/25/11 11:27 AM
11/25/11 11:27 AM
Jacksonville Florida
elitecustombody Offline
I don't know what kind of hokey setup you use but my air is dry and clean before it gets to the hose going to my gun.
Tom, did you ever stop to think that a guy who has made a living restoring cars in Florida might know a thing or two about moisture and humidity as it relates to painting cars?
...hokey setup I suspect you are underestimating the expertise on this board.
Greg,
I never underestimated the expertise on this board I have gained tons of knowledge from this forum and appreciate it 100%.
I just questioned Elites ability to thoroughly read a post before taking pot shots at it. I would figure that a "Professional painter" would know that air would be clean and dry before it went into the hose going to the gun. Unless he's the kind of " Professional painter" that has a filter and refrigerated dryer attached to his gun while he paints.
73,I could not decipher much from the run-on mess with something about painting 73 roadrunner heater core.
Most compressed air refrigerated dryer are compact in size and are usually installed right after compressor.My air supply dryer/filtration setup has been working just fine for 15 years.BTW,every shop has different air compressors,dryers,filters,e.t.c. ,which vary not only by size,output,brand,e.t.c., but by age, maintenance or lack of and many other significant factors,so I do not assume that every shop's air supply is just as clean as another.
Maybe you need a backpack heater for your air supply to paint gun at Noth Pole Restorations ?
And waiting 50 minutes between coats of clear? Really? I guess that's how it's done by professional painters on North Pole
That kind of advice can ruin months of someone's hard work. Because there are hundreds of clearcoats on the market with many options of reducers and hardeners for various temperatures and speeds.Many of them will react different to fresh coat after 20,30,40,50 or more minutes.So,unless you know which specific clear,reducer and hardener OP is using, I would keep that advice to yourself .
Re: Painting questions... [Re: elitecustombody] #1119861
11/25/11 11:44 AM
11/25/11 11:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Once I shoot a clear coat I thin the remaining
amount and start shooting again... the voc need to
float up through... pretty hard when its dry
Re: Painting questions... [Re: RodStRace] #1119862
11/25/11 06:59 PM
11/25/11 06:59 PM
Heart of Ohio
4boxers4 Offline OP
4boxers4  Offline OP
Heart of Ohio
ok I can wash over epoxy but not bodywork? How do I get it clean in that stage(prep for primer)? I will get some of the Dupont 3901. Would I need an additional sealer over my epoxy paint(Zero Rust) or can I just go straight to color? Thanks for all the help...sorry for soooo many questions but that is how you learn, without too many mistakes.
Anyone ever heard of a shelf life for paint, even if it is kept in a temp controlled envoironment? Thanks
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Painting questions... [Re: 4boxers4] #1119863
11/25/11 10:54 PM
11/25/11 10:54 PM
md
W
wicked Offline
wicked  Offline
W
md
blow off car, prep wipe, tack, prime. Most paint systems suggest you use "their" sealer prior to top coats. Not sure on zero rust products but most epoxy primers I've used have a re-coat window check the specifics on their products on whats required. Catalyzed paints are photo-reactive(think that's what it was called) so anything that's been opened for a good length of time is suspect, if it doesn't properly catalyze you have a real mess.
The best advice I can give you is to follow the paint manufactures guidelines , most have info sheets available, they have it scienced out to achieve decent results, some of the info posted in this thread I don't agree with such as over reduction of materials and excessive flash times can lead to problems such as delamination , die back, solvent popping, and a less durable finish, much better to learn to paint the materials as designed.
Re: Painting questions... [Re: wicked] #1119864
11/25/11 10:59 PM
11/25/11 10:59 PM
florida
74fldart Offline
74fldart  Offline
florida
i have used paint that was in the can for almost 10 yrs and it worked fine. but i dont recommend doing it.
Re: Painting questions... [Re: 74fldart] #1119865
11/25/11 11:36 PM
11/25/11 11:36 PM
md
W
wicked Offline
wicked  Offline
W
md
Alkyd's and most acrylic's would be fine, urethane's tend to turn into a gooey mess that never dries
Re: Painting questions... [Re: MR_P_BODY] #1119866
11/26/11 01:39 AM
11/26/11 01:39 AM
Is that what you got from data sheet ? This may have worked with cheap lacquer ,but it's a bad idea for urethane products. Reducing clearcoat will cause dieback, making it dull,easy to scratch,chip and will lead to premature deterioration.Even if you try buffing,it will not have the gloss and luster of properly mixed and applied urethane clearcoat. Just wondering, what kind of warranty your paint jobs come with?
Re: Painting questions... [Re: elitecustombody] #1119867
11/26/11 01:48 AM
11/26/11 01:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I got that from a painting instructor and I asked a
rep for the company.. he said its fine also... plus
the thinner evaporates
Re: Painting questions... [Re: MR_P_BODY] #1119868
11/26/11 02:51 AM
11/26/11 02:51 AM
If I were you, I'd find product data sheet instead of listening to your painting instructor or rep. Usually they are easily obtainable online.
Re: Painting questions... [Re: MR_P_BODY] #1119869
11/26/11 03:14 AM
11/26/11 03:14 AM
md
W
wicked Offline
wicked  Offline
W
md
Not wanting to get into a pissin contest, but I have been through PPG school , Dupont school, through several in shop demo's by by such companies as Sikkins , Standox, and Glasurit by factory reps, none ever suggested deviating from the engineered reduction ratio's because they actually work. There is no need to deviate. The issues I presented in my previous post(several posts back) still hold true, over reduction produces weakened film strength (due to all that extra reducer) and a less durable finish. Some paint systems over reduction of clear will re-float the metallic in your base or wrinkle it ruining your paint job.
If what you do works for you, cool, while the results are satisfactory, your not achieving the level of finish you could be, given the materials your using, if you stick to the paint manufactures guidelines.
Re: Painting questions... [Re: wicked] #1119870
11/26/11 03:26 AM
11/26/11 03:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
What ever guys... its been working for me for years
now and I plan on continuing the same process...
(by the way it was a PPG rep)
Re: Painting questions... [Re: MR_P_BODY] #1119871
11/26/11 09:36 AM
11/26/11 09:36 AM
md
W
wicked Offline
wicked  Offline
W
md
Some of those ppg reps can come in pick up a gun and show you how to use their materials properly. Some are just pushing product. not picking, just saying
Re: Painting questions... [Re: wicked] #1119872
11/26/11 10:57 AM
11/26/11 10:57 AM
Re: Painting questions... [Re: wicked] #1119873
11/26/11 11:21 AM
11/26/11 11:21 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I seen it done alot in the paint shop/lab at Chrysler
by the painters there... I tried it like the sheet
says also
Re: Painting questions... [Re: elitecustombody] #1119874
11/26/11 12:02 PM
11/26/11 12:02 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Elite said " Not wanting to get into a pissin contest," Hahahah now that's funny sh&t there. I would have never thought that after reading "ALL" of your posts. You sound like my neighbor who worked behind a paint supply counter for 25+ years. He thinks he knows everything there is to know about painting too. He painted 2 cars in his life both looked like crap and the clear coat was falling off of 1 less than 2 years later.
OP, You have some good information here unfortunately it's hard to figure out because Elite is littering this thread as he "TRIES" to prove he knows what he's talking about. Go to the link I sent you (autobody 101) You will find people there that have actually painted a car and know what their talking about (Like some of the people that posted in this thread) But you won't find people that just think they do like elite (Not wanting to get into a pissin contest, Hahhaha That's still funny sh&t) Hahhahahah
Re: Painting questions... [Re: 73rrak] #1119875
11/26/11 12:33 PM
11/26/11 12:33 PM
This comes from someone that was just questioning my ability to thoroughly read a post before taking pot shots at it.
I quote your useless post just so you can't go back and edit.
Now go back and pay close attention to my previous post. I quoted wicked's post agreeing with him. So keep talking out of your a$$,you're just making that hole deeper.I'm not even going to post pics of my work because you're just a troll . Go install couple more heater cores in your air supply,you might get even better results and don't forget to wait couple hours between coats,you might just come up with the ultimate paint job ever
Re: Painting questions... [Re: 73rrak] #1119876
11/26/11 03:13 PM
11/26/11 03:13 PM
md
W
wicked Offline
wicked  Offline
W
md
I said it, and I never worked behind a paint counter. I've done it for a living, and painted a lot of cars over my lifetime with all different materials. They all worked mixed as per the directions.
Re: Painting questions... [Re: elitecustombody] #1119877
11/26/11 03:34 PM
11/26/11 03:34 PM
Alaska
73rrak Offline
73rrak  Offline
Alaska
Hahahahhahha Yup no pissing contest here. Hahahahhahha That's still some funny sh&t Hahahahhahha
Re: Painting questions... [Re: wicked] #1119878
11/26/11 03:35 PM
11/26/11 03:35 PM
md
W
wicked Offline
wicked  Offline
W
md
To the OP. Original point being, I can't condone playing chemist, It's already been scienced out. Focus on application. To give an example, I put a coat of clear on watch it lay down and how long it takes to flash, this gives some parameters for applying the next coat,you know how it's going to handle, change reduction the next coat will handle differently. More variables introduced. You'll have enough going on without turning it into a chemistry experiment. The materials being consistent from coat to coat will accelerate your learning curve.
Re: Painting questions... [Re: 73rrak] #1119879
11/26/11 04:34 PM
11/26/11 04:34 PM
It's good to know that you have sense of humor laughing at how you owned yourself.
Page 2 of 3 1 2 3
