Hemi Guys...what'll it make ? #1119594
11/23/11 03:17 AM
11/23/11 03:17 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Fresh 572" Combo in a street/strip appn is as follows:
Hemi mega block 4.5" bore - o-ringed
4.5" Crower Ultra-lite crank
Oliver rods
12.5:1 CP lightweight pistons - gas ported
Sealed Power rings
ARP rod, crank, head studs, oil pan studs, flywheel bolts
Crower roller 689/652" lift 278/285 @ .050" & Crower lifters
MP heads ported with Ferrea 2.3" intake
Dick Landy rollers
Mallory dist
Indy port SP intake
1050 Dom (have an 1150 as well)
Billet electric water pump
Milodon ext dual line swinging pickup and pump
Anhy thoughts on HP/TQ estimates ?
Will duration @ .050" allow pump gas (marginal I know)
What would you change?
Hemi guys fire away....
Thx
Re: Hemi Guys...what'll it make ? [Re: LAD 524] #1119595
11/23/11 05:26 AM
11/23/11 05:26 AM
Netherlands
72Challenger Offline
Netherlands
flywheel
No way an expert but comparing it to mine I would guess around 800-850 hp depending on the level of porting and final compression. Also would suggest the 1150 dominator but that's an easy try as you already have it.
Sounds like an low maintenance dependable street strip combo
Re: Hemi Guys...what'll it make ? [Re: 72Challenger] #1119596
11/23/11 05:38 AM
11/23/11 05:38 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
750
home of the
Sox and Martin Hemi Duster
Re: Hemi Guys...what'll it make ? [Re: HEMIFRED] #1119597
11/23/11 08:19 AM
11/23/11 08:19 AM
pa
572charger Offline
572charger  Offline
pa
what do the heads flow ? more they flow the better u go !!! LOL 700-750 hp cam looks good more lift if the heads flow up there !!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: Hemi Guys...what'll it make ? [Re: LAD 524] #1119598
11/23/11 09:21 AM
11/23/11 09:21 AM
an8sec70cuda Offline
I think it'll depend on the heads. Who ported them?
Sounds VERY similar to mine, but w/ more compression. Definitely use the 1150 carb.
Ought to make 800+ easily if the heads are good.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi Guys...what'll it make ? [Re: an8sec70cuda] #1119599
11/23/11 10:49 AM
11/23/11 10:49 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
+850hp for sure.
Typically the exhaust valve has to be rotated a couple of degrees for clearance to clear that size intake valve, who offers MP heads with that size valve? I thought Stage V and Indy were the only ones. You also have 1 more point of compression than mine, but your cam and intake are milder. That engine will be a beast if those heads flow what the others do with that size valve! As far as pump gas goes, until you get it sorted out, I would limit timing to 34* and run 50/50 mix. It will be very close, but it might make it. Is it in an aluminum block, I am assuming no because you said mega block? Wish mine had 2.30" intake valves...
Re: Hemi Guys...what'll it make ? [Re: Dragula] #1119600
11/23/11 02:54 PM
11/23/11 02:54 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That big Hemi with that little cam is going to be a torque monster.
I'll say 860 horse at 6500, 760 ft lbs at 4800, with a torque curve flat enuff to make a pool table blush.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Hemi Guys...what'll it make ? [Re: Hemi_Joel] #1119601
11/23/11 08:04 PM
11/23/11 08:04 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Interestinmg comments guys
I was leaning to the 1150, any recommendations on a decent carb builder as well ?
I don't have the flow spex on the heads as yet. So you guys think I can get away with 34 deg total with 50/50 mix?
Also with that cam, what would the rpm range be in a 572 Hemi and what convertor/gearing would suit with a 727 in an A body. Gearing is flexible !!
Lastly, would the Crower lifters last on the street with that cam/spring combo and do I need different lifters ie: Isky red zone ?
Thanx for the input fellas....
Re: Hemi Guys...what'll it make ? [Re: LAD 524] #1119602
11/23/11 08:34 PM
11/23/11 08:34 PM
820-825, Only thing that will be holding you back are those heads.
Cam is a little small but not too bad.
Re: Hemi Guys...what'll it make ? #1119603
11/23/11 08:41 PM
11/23/11 08:41 PM
Houston,Tx.
Lee446 Online content
Lee446  Online Content
Houston,Tx.
Are you actually going to put it on an engine dyno so we will find out? Without more head flow info, I would say 740hp.
Re: Hemi Guys...what'll it make ? [Re: Lee446] #1119604
11/23/11 08:44 PM
11/23/11 08:44 PM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
If I get my grubby little mits on this engine yeah it'll go on the dyno !!
Without the flow spex, it'll be harder to estimate HP/TQ.
Keep em comin fellas.
