Summit Radiators #111939
08/29/08 12:25 AM
08/29/08 12:25 AM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
http://store.summitracing.com/partdetail...mp;autoview=sku
Anybody put either one of these into a B-Body with a 22" core support? How did it fit? How did it work? Which one would fit best?
Re: Summit Radiators [Re: StealthWedge67] #111940
08/29/08 02:02 AM
08/29/08 02:02 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Those are good radiators if the rest of your cooling system is working well. The 381428 does not have brackets so you would have to weld those on. Do you have 29" to 30" of space across the core support.
Re: Summit Radiators [Re: 68Fastback] #111941
08/29/08 08:09 PM
08/29/08 08:09 PM
Puyallup, WA
Puyallup, WA
It would be tight. I'd have to move my stock overflow canister . but I suppose that isn't such a big deal. As I continue to want to go fast, the car gets further & further from stock anyway. these look to be the exact same radiator, only the "direct fit" one has the mounting flanges attached.
Re: Summit Radiators [Re: StealthWedge67] #111942
08/29/08 08:17 PM
08/29/08 08:17 PM
NH
72challorange Offline
He's Game
He's Game
NH
I have the "direct fit" one in my E-body 22" opening. It fits the opening perfect, but it is tight by the Battery tray. Everything fits though and I have a overflow and washer tank over on the otherside as well.
Tom
By tdavist, shot with DSC-P72 at 2008-05-24
By tdavist, shot with DSC-P72 at 2008-05-11
Re: Summit Radiators [Re: 72challorange] #111943
08/29/08 08:23 PM
08/29/08 08:23 PM
Puyallup, WA
Puyallup, WA
Thats exactly the area I'm concerned with, the battery tray. Can you tell me exactly how far off the support the radiator stands in that area? Can you take a picture of that intersection & send it to me? I really appreciate it.
Re: Summit Radiators [Re: StealthWedge67] #111944
08/29/08 08:41 PM
08/29/08 08:41 PM
NH
He's Game
He's Game
NH
Hot off the press.
Tom
By tdavist
By tdavist
Re: Summit Radiators [Re: 72challorange] #111945
08/29/08 09:04 PM
08/29/08 09:04 PM
Puyallup, WA
Puyallup, WA
Thanks! The E-body battery tray is quite a bit different than my '67 B-body, but it still gives me a good look at the situation. Worst case.... I move the battery to the trunk & use that area for a remote dual oil filter setup
(Mo' money, Mo' money, Mo' money......)
At this rate, I'll never get the 451 built. but this is all stuf that needs to be done to support more motor anyway, right? Thanks again for the pics. They show me exactly what I thought would be the case with the mounting brackets vs. the core support. looks like it would fit better if the core support panels were flat. You seem to have made it work & look decent, though.
Re: Summit Radiators [Re: StealthWedge67] #111946
08/29/08 09:41 PM
08/29/08 09:41 PM
NH
He's Game
He's Game
NH
Good enough. If I were to do it again, I'd get the one without flanges and use the top and bottom mount kit they sell.
I used some flat stock behind it to mount my trans cooler too.
Tom
By tdavist
By tdavist, shot with DSC-P72 at 2008-04-07
Re: Summit Radiators [Re: 72challorange] #111947
08/29/08 10:52 PM
08/29/08 10:52 PM
Puyallup, WA
Puyallup, WA
Thats good info, because the one without those mounting tabs is about $50 cheaper, and the mounting kit is only $16.
Thanks again
Re: Summit Radiators [Re: StealthWedge67] #111948
08/29/08 11:14 PM
08/29/08 11:14 PM
wi.
Rosco Offline
Rosco  Offline
wi.
I used the Summit direct fit for my 67GTX.Fit very well,just drill one hole for the drivers side lower bolt location.
Re: Summit Radiators [Re: Rosco] #111949
08/29/08 11:26 PM
08/29/08 11:26 PM
Puyallup, WA
Puyallup, WA
Did the stock hoses still fit properly?
Re: Summit Radiators [Re: 72challorange] #111950
08/30/08 12:05 AM
08/30/08 12:05 AM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Great info, and sorry to hijack, but where did you get that shroud?
-Michael
SuperBeast
An enforcer for the Mopar Mafia!
Re: Summit Radiators [Re: sycboi] #111951
08/30/08 08:42 AM
08/30/08 08:42 AM
NH
He's Game
He's Game
NH
I got it from Don at FBO.
It is a Northern piece, summit doesn't seem to want to sell these. At least they didn't when I was looking.
Tom
IIRC it was <70 to my door.
I used the stock hoses and trimmed them just a bit to fit.
Re: Summit Radiators [Re: 72challorange] #111952
08/30/08 11:50 AM
08/30/08 11:50 AM
NY
X
xghobo Offline
xghobo  Offline
X
NY
FBO....?? I cant figure it out.
But i want one..
71 Cuda vert hemi clone(in progress) 69 Charger R/T 440 06 Hemi Ram 1500
Re: Summit Radiators [Re: xghobo] #111953
08/30/08 12:12 PM
08/30/08 12:12 PM
NH
He's Game
He's Game
NH
Re: Summit Radiators [Re: 72challorange] #111954
08/30/08 02:40 PM
08/30/08 02:40 PM
BDW Offline
BDW  Offline
72,
That looks great, nice set-up!
Re: Summit Radiators [Re: BDW] #111955
08/30/08 03:45 PM
08/30/08 03:45 PM
NH
He's Game
He's Game
NH
Thanks, it takes a bit to fit it up but works well.
Tom
