RB intake porting,welding or adaptors? #1119421
11/22/11 08:49 PM
11/22/11 08:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
used with max wedge or even bigger ports to match big port heads like a 44-1 or B-1 origenal.on my BDS intake i would like to have a better head and just weld or use an adaptor to match the ports.to be honest i am not sure when/if the intake angle changes on what heads.any header issue will be delt with.9hooker supercomp 2"x34 69 B body]thanks for your help.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119422
11/22/11 09:00 PM
11/22/11 09:00 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
If I'm reading this right you need to know how to adapt a BDS manifold to a Max Wedge port?
First, B-1 heads have a different angle and the port size is to big and wide. So if you ask me that is off the table.
Second, The Max Wedge head port is taller so you could cut the top of the runners off and weld on a taller runner to match the Max Wedge port. Seems like a lot of work for what you might get out of it. I would just get the smaller pulley for the blower.
Re: RB intake porting,welding or adaptors? [Re: Biginchmopar] #1119423
11/22/11 09:18 PM
11/22/11 09:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
you have helped a bunch!i know what you meen about the pulley!
welding the intake i was not sure how much could be done on the roof or taper or how to fix it.an intake can be big $$ as you know.
i thaught the 440-1 cnc would be an option.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119424
11/22/11 10:30 PM
11/22/11 10:30 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Why go though all that trouble when Indy sells a Blower intake for there heads? Im sure there is guys who can make about any intake you want for what ever reason, and what ever head..
Just takes some $$
Re: RB intake porting,welding or adaptors? [Re: Bob_Coomer] #1119425
11/22/11 10:47 PM
11/22/11 10:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
ok give me the $$ then. sorry but i want to use my intake and the info on my q is helpfull to me.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119426
11/23/11 01:32 AM
11/23/11 01:32 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Like BigInch said, the B-1 is really not an option, but welding the top of the runners is definitely do-able for the max-wedge port window. Not sure I understand how Big was suggesting doing it, but back in the late 60's, Sox & Martin had at least one Max-wedge 440 with an Edelbrock 440 port size CH4B (or DH4B, whichever one fit the RB)with the tops of the runners welded up and the port opened up to the Max port. Seemed pretty exotic at the time but much more doable now, especially with the blower intake, as the best I remember on the BDS, the runners are relatively short and a pretty straight shot from the inner plenum to the port. You could probably rough out the ports with an end mill and then die-grind to final size, it will take a decent aluminum welder to lay the material in, of course, and it will take some work, but still a lot easier on the pocketbook than the Indy option. It's always amazing to me that others find it so easy to spend "Your" money.......
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: RB intake porting,welding or adaptors? [Re: 23T Hemmee] #1119427
11/23/11 12:33 PM
11/23/11 12:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
thanks for posting.yes the port is streight and only 4" long tops so i think only 2" of the port would need welded.i will go take some pics.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119428
11/23/11 01:17 PM
11/23/11 01:17 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i will have to get a roof thickness.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119429
11/23/11 01:37 PM
11/23/11 01:37 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I would try it. I think the new heads are a must for your car. CnC -1s will wake your car up a ton.
Re: RB intake porting,welding or adaptors? [Re: FastmOp] #1119430
11/23/11 01:47 PM
11/23/11 01:47 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
ya from 280 cfm to 350 you bet.
Re: RB intake porting,welding or adaptors? [Re: Clanton] #1119431
11/23/11 03:56 PM
11/23/11 03:56 PM
Carson City, Nevada
Carson City, Nevada
From the pictures you posted it looks like you might make it by just opening the port to the Max Wedge size, if you go through it might not be by much.
You could weld it up or use epoxy (the easy route) if you go through. I would only go into the port an inch or so.
Lay a Max Wedge gasket on it and see what it looks like.
Re: RB intake porting,welding or adaptors? [Re: Biginchmopar] #1119432
11/23/11 04:42 PM
11/23/11 04:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
again,Thank you!any epoxy would be in the enclosed area and sound very valid.
Re: RB intake porting,welding or adaptors? [Re: Biginchmopar] #1119433
11/23/11 07:23 PM
11/23/11 07:23 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
I thought it looked like there might be enough in the casting to go out to Max,too Problem is if you do break through its harder to weld up thin aluminum than it is to weld it up when its thicker to start with. Problem with epoxy on a blower manifold, it may hold up to the boost, but might blow out if it ever backfires, even with a pop off valve, just something to think about.
Ronny
John 14:6
Re: RB intake porting,welding or adaptors? [Re: 23T Hemmee] #1119434
11/23/11 07:37 PM
11/23/11 07:37 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
i agree if welded pre welding is the way to go.i have epoxy in my iron heads now but not a thru wall.i will do lots of pre-measuring.
