Re: RB intake porting,welding or adaptors?
[Re: Biginchmopar]
#1119423
11/22/11 09:18 PM
11/22/11 09:18 PM
Posts: 4,488 northern,Ohio,USA
Clanton
northern,Ohio,USA
you have helped a bunch!i know what you meen about the pulley! welding the intake i was not sure how much could be done on the roof or taper or how to fix it.an intake can be big $$ as you know. i thaught the 440-1 cnc would be an option.
[Re: Clanton]
#1119424
11/22/11 10:30 PM
11/22/11 10:30 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Why go though all that trouble when Indy sells a Blower intake for there heads? Im sure there is guys who can make about any intake you want for what ever reason, and what ever head.. Just takes some $$
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#1119425
11/22/11 10:47 PM
11/22/11 10:47 PM
Clanton
northern,Ohio,USA
ok give me the $$ then. sorry but i want to use my intake and the info on my q is helpfull to me.
[Re: Clanton]
#1119426
11/23/11 01:32 AM
11/23/11 01:32 AM
Posts: 588 Franklin, TN
23T Hemmee
Franklin, TN
Like BigInch said, the B-1 is really not an option, but welding the top of the runners is definitely do-able for the max-wedge port window. Not sure I understand how Big was suggesting doing it, but back in the late 60's, Sox & Martin had at least one Max-wedge 440 with an Edelbrock 440 port size CH4B (or DH4B, whichever one fit the RB)with the tops of the runners welded up and the port opened up to the Max port. Seemed pretty exotic at the time but much more doable now, especially with the blower intake, as the best I remember on the BDS, the runners are relatively short and a pretty straight shot from the inner plenum to the port. You could probably rough out the ports with an end mill and then die-grind to final size, it will take a decent aluminum welder to lay the material in, of course, and it will take some work, but still a lot easier on the pocketbook than the Indy option. It's always amazing to me that others find it so easy to spend "Your" money.......
[Re: 23T Hemmee]
#1119427
11/23/11 12:33 PM
11/23/11 12:33 PM
Clanton
northern,Ohio,USA
thanks for posting.yes the port is streight and only 4" long tops so i think only 2" of the port would need welded.i will go take some pics.
[Re: FastmOp]
#1119430
11/23/11 01:47 PM
11/23/11 01:47 PM
Clanton
northern,Ohio,USA
I would try it. I think the new heads are a must for your car. CnC -1s will wake your car up a ton.
ya from 280 cfm to 350 you bet.
[Re: Biginchmopar]
#1119433
11/23/11 07:23 PM
11/23/11 07:23 PM
23T Hemmee
Franklin, TN
From the pictures you posted it looks like you might make it by just opening the port to the Max Wedge size, if you go through it might not be by much.
You could weld it up or use epoxy (the easy route) if you go through. I would only go into the port an inch or so.
Lay a Max Wedge gasket on it and see what it looks like.
I thought it looked like there might be enough in the casting to go out to Max,too Problem is if you do break through its harder to weld up thin aluminum than it is to weld it up when its thicker to start with. Problem with epoxy on a blower manifold, it may hold up to the boost, but might blow out if it ever backfires, even with a pop off valve, just something to think about.
