Help to ID this cast alternator mount bracket..Thanks #1119414
11/22/11 07:05 PM
11/22/11 07:05 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
looks like # is 2806039 .. What applications is this for? . came off a 67 440 HP motor, but I dont believe it is correct for 67 , is it? thanks
76 DODGE VAN PRO STREET 67 DODGE CORONET R/T 480 STROKER
Re: Help to ID this cast alternator mount bracket..Thanks [Re: Provan] #1119415
11/23/11 12:31 PM
11/23/11 12:31 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
Re: Help to ID this cast alternator mount bracket..Thanks [Re: Provan] #1119416
11/23/11 12:54 PM
11/23/11 12:54 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I'm guessing mid 60s but there are plenty of people here who can nail the dates down better. I haven't seen one in a while but I remember taking one of them many years ago and notching out the bottom section to allow the alternator to sit down low vice upwards since I had blocked off the mechanical fuel pump. It worked quite nicely and made it look a bit less cluttered up top.
Re: Help to ID this cast alternator mount bracket..Thanks [Re: Provan] #1119417
11/23/11 01:38 PM
11/23/11 01:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Lower alt bracket 1967 - 1968 B series engines with factory air.
Sorry, I don't know if they are different between B and RB engines
