63/65 rear axle #1119388
11/22/11 06:34 PM
11/22/11 06:34 PM
somewhere out there
Billy no mates Offline OP
somewhere out there
Guys,
I'm sure this question must have been asked before. Other than the axle lengths what's to stop the axles & brakes from a 65 axle fitting into a 63 axle case? Is it possible?
Thanks Billy
BillyNoMates
Re: 63/65 rear axle [Re: Billy no mates] #1119389
11/22/11 08:10 PM
11/22/11 08:10 PM
SCVpolara Offline
SCVpolara  Offline
Chrck with DrDiff he would have the answers for you
Re: 63/65 rear axle [Re: Billy no mates] #1119390
11/22/11 08:23 PM
11/22/11 08:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
B-body or C-body? If you're asking about the B-body, the '65 axles are about 1/2" too long for the '63 housing.
The brakes would fit with the proper length axles and Green bearings.
Re: 63/65 rear axle [Re: Billy no mates] #1119391
11/22/11 09:28 PM
11/22/11 09:28 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
two totally different axles..
the 63 has the tapered/keywaued axle, the drums have the hub swedged to them. and the bearings are smaller in outer diameter.
the 65 has the separate drums and hubs like all the 8 3/4 rears till 74
I am truckless..
Re: 63/65 rear axle [Re: 340SHORTY] #1119392
11/22/11 09:45 PM
11/22/11 09:45 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
the biggest problem with B body axle shafts is that every 2-3 years they make them 1/8 inch wider or more which means when you replace them you have to order custom axles if you cant find the exact year used replacement---however A and C body axle shafts stayed constant at 28 inch and 30 inch which makes life simple because you can buy them for $100-130----the A body set up makes more $ sense to the hobbyist because the housing cutdown should be about $100+ $250 for 2 new axles---if you buy 2 new custom axles from someone like moser it will be $500----yes the A body axle fits under a 70 roadrunner---done it several times---yes you have to move the spring pads--thats the something the housing narrowing person can do for you----bob
Re: 63/65 rear axle [Re: savoy64] #1119393
11/23/11 12:15 AM
11/23/11 12:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I put a complete drum to drum 8-3/4 rear from a 65 B-body in to my 63 Sport Fury. Bolted right in and worked great and got rid of the pressed drums. Ron
Re: 63/65 rear axle [Re: 383man] #1119394
11/23/11 01:05 AM
11/23/11 01:05 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
FWIW, my '63 & '64 housings were different widths. Both had the tapered axles, of course.
Re: 63/65 rear axle [Re: topside] #1119395
11/23/11 01:10 AM
11/23/11 01:10 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
'62-3 are the same and the most narrow, the '65 housing is more narrow than the '64 ('64 MW cars used the '62-3 housing).
Re: 63/65 rear axle [Re: 70440+6bbl] #1119396
11/23/11 01:21 AM
11/23/11 01:21 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Aren't the 1965, 1966, and 1967 B-bodies rears the same width?
Re: 63/65 rear axle [Re: autoxcuda] #1119397
11/23/11 01:44 AM
11/23/11 01:44 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
No, the '66-67 housings are 1/4" narrower than the '65. ('65=54.5"/'66-7=54 1/4")
Re: 63/65 rear axle [Re: 70440+6bbl] #1119398
11/23/11 02:38 AM
11/23/11 02:38 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
'65-'67 housings are identical (54.25" end to end).
BTW, I sell new, 1 piece, high-strength axle shafts for any '62 and newer housing ($300 pair with studs and green bearings installed).
Re: 63/65 rear axle [Re: DoctorDiff] #1119399
11/23/11 02:46 AM
11/23/11 02:46 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Dr.Diff,
I got the measurements I posted above from the "Guide to the Chrysler 8 3/4 rear" chart, I haven't checked all of the measurements, since I don't have every axle housing variation, but, the five different housings I checked against it were quite accurate. I'll keep your info handy though.
Re: 63/65 rear axle [Re: DoctorDiff] #1119400
11/23/11 06:30 AM
11/23/11 06:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Dr Diff would them axles work fine in my 63 since I race it a few times a year ? And are they the right lenth since I have a 65 B-body rear ? I plan to replace the stock axles in my rear now some time in the next year. Oh and can I get them with the longer 1/2" studs ? Ron
Re: 63/65 rear axle [Re: 383man] #1119401
11/23/11 09:48 AM
11/23/11 09:48 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ron just get the 65 axles.The long studs fit the axles.My kid runs my 65 axle in his 62 300 with long studs.Been in for at least 5 years now.When we scrap the 66 Charger Im pulling the rear as a spare for my 65 which has a 69 R/T rear now.Rocky
Chrysler Firepower
Re: 63/65 rear axle [Re: 383man] #1119402
11/23/11 12:49 PM
11/23/11 12:49 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Yes. I make custom length axle packages as well as correct length axle packages for '62-'63, '64, '65-'67, '68-'70 and '71-'74 B-body rears in 30 and 35 spline. Choose standard length press-in, 2" screw-in or 3" screw-in lug studs.
Re: 63/65 rear axle [Re: DoctorDiff] #1119403
11/23/11 01:50 PM
11/23/11 01:50 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I thought the housing ends were different between the tapered axle rears and the later rears ?
Also what is the length of the 62/63 rear ?
Re: 63/65 rear axle [Re: JohnRR] #1119404
11/23/11 03:02 PM
11/23/11 03:02 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
With the exception of the shallower axle seal bore, '62-'64 housing ends are the same as the newer version. In other words, you must run a narrower wheel bearing lock ring to clear the inner seal.
Correct housing widths are listed in Moparts Tech Archives as well as Hollander's Interchange.
B-body housing widths (end to end):
'62-'63= 53 1/4" (And '64 Max Wedge)
'64 = 55 5/8" (Exc. Max Wedge)
'65-'67= 54 1/4"
'68-'70= 54 15/16"
All these housings share the same perch dimensions (44" on center, pinion 4 degrees up when perches are level).
Re: 63/65 rear axle [Re: DoctorDiff] #1119405
11/23/11 07:16 PM
11/23/11 07:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
'65-'67= 54 1/4"
'68-'70= 54 15/16"
Where do you get the narrower wheel bearing lock ring ? Could a person use a tapered bearing in that 62-63 housing with the narrower ring ?
Re: 63/65 rear axle [Re: JohnRR] #1119406
11/23/11 09:10 PM
11/23/11 09:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Never knew a narrower collar was available. To me, the only reason to use the Green bearings on this installation is to be able to remove the inner seal and not have to worry about seal/collar interference.
Re: 63/65 rear axle [Re: JohnRR] #1119407
11/23/11 10:44 PM
11/23/11 10:44 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Bearing Technologies (Green Bearing Company) makes the narrow lock ring.
In fact, ST-400 Green bearings come with the narrow ring included in the kit. BTW, the only difference between the MO-400 and ST-400 Green bearings is the width of the lock ring.
