Re: K-FRAME PAINT??? [Re: QuickDodge] #1119219
11/23/11 02:18 AM
11/23/11 02:18 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Alkyld enamels, such as Rustoluem, two biggest faults are chalking due to UV light exposure (from the sun, etc.) and chemical resistance. Adding some hardener will increase the chemical resistance considerably. Parts underneath the car receive minimal UV light exposure, so Rustoleum with some hardener added should hold up well. This type of finish would be acceptable for a summer time week-end car.
Will any kind of hardener for enamel work?
Re: K-FRAME PAINT??? [Re: Labratt] #1119220
11/23/11 08:57 AM
11/23/11 08:57 AM
Dry Heat AZ
AAR#2 Offline
AAR#2  Offline
Dry Heat AZ
Check around your area, in AZ powdercoating fees vary greatly. The guys I go to now are awesome and the $$ is great. They have a $30 minimum for any one color. I remember once I had 12 items, all smaller, leaf spring brackets front and rear, rear shock perch, leaf spring bumper (attached to frame), upper control arms . . . . and was only charged the min $30. I've decided its cheaper for that (all things considered) than for me to strip/blast, prime and paint.
That said others in the area charge in the neighborhood of 70% more
Re: K-FRAME PAINT??? [Re: Labratt] #1119221
11/23/11 09:44 AM
11/23/11 09:44 AM
Slantytown
DUFFMAN Offline
Ask And Ye Shall Receive
DUFFMAN  Offline
Slantytown
The last 2 k-frames I painted I used black farm implement paint on. It's extremely durable and even sticks to rust. Tractor Supply carries it if you have them in your area.
No longer taking $h!t from anyone!
Re: K-FRAME PAINT??? [Re: AAR#2] #1119222
11/23/11 10:33 AM
11/23/11 10:33 AM
Cincinnati, Ohio
chargincharles Offline
Cincinnati, Ohio
I know I'm gonna get hit for this BUT-
I've used POR-15 semigloss black on a few K-frames and never had any issues. Still holding up fine on my 5th at the moment.
That being said-
IF OEM is no concern, and the K is out and ready- Powder Coating IS the only way to go.
Good luck with it!
CC.
Re: K-FRAME PAINT??? [Re: Labratt] #1119223
11/23/11 11:03 AM
11/23/11 11:03 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Lew..FORTY DOLLARS??? What a deal! Hopfully,Bill at QC Coatings can give me a similiar price! Powder Coating seems like the way to go...if the price is NICE! Thank You ALL for your opinions..and experiences! I truly appreciate it! Randy B.
Randy I think that powder coating is only that cheap in Arizona , I've never been able to get something done that cheap here in the northeast .
Re: K-FRAME PAINT??? [Re: JohnRR] #1119224
11/23/11 02:09 PM
11/23/11 02:09 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Hmmmm;
I powdercoated mine, but despite all the rhetoric, ANYTHING you do is better than the thin coat of GLOSS black the factory used. It's nice to use the best product available, but for the useage of the average hobbiest, anything better than a spray bomb is overkill.....which is fine.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: K-FRAME PAINT??? [Re: DPelletier] #1119225
11/24/11 12:37 AM
11/24/11 12:37 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks everyone! Because of time restraints,I think I'm going to check out the farm implement paint from Tractor Supply. My painter wants the car to him by the end of the month...next wednesday or thursday! My powder coater has a pretty long back-log right now,anyway! Thanks again! Randy B.
Re: K-FRAME PAINT??? [Re: Labratt] #1119226
11/24/11 09:25 AM
11/24/11 09:25 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Randy, that implement paint(TSC) is some TOUGH stuff...
I painted my crawler loader(the yellow front loader
thats up north) with it about 20 years ago.... you
can brush it on OR thin it and spray it
Re: K-FRAME PAINT??? [Re: MR_P_BODY] #1119227
11/24/11 10:56 AM
11/24/11 10:56 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Mike! Do you think a quart will be enough..if I brush it on? I will probably paint the steering components with it,as well!
Re: K-FRAME PAINT??? [Re: Labratt] #1119228
11/24/11 11:32 AM
11/24/11 11:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A QT is plenty(plus that stuff has a UV protectant)
Re: K-FRAME PAINT??? [Re: Challenger 1] #1119229
11/24/11 12:48 PM
11/24/11 12:48 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Chassis black from Eastwood has proven to be a very durable paint out of a spray can for me.
BTW...just got an email that they have it on sale for black Friday.
Re: K-FRAME PAINT??? [Re: OzHemi] #1119230
11/25/11 01:26 AM
11/25/11 01:26 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for the info,Mike...and Jeff!
Re: K-FRAME PAINT??? [Re: Labratt] #1119231
11/25/11 11:36 AM
11/25/11 11:36 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
How does the Eastwood paint compare to SEM Trim Black? Is the Trim Black close to the correct color or should there be more gloss? I've got some of the REM paint and I'm wondering if I should order some of the chassis black.
Eastwood lists Chassis Black(satin and gloss) AND Extreme Chassis Black (satin and gloss) What's the difference? Would a coat of Diamond clear over the Chassis Black be a good idea?
Re: K-FRAME PAINT??? [Re: burdar] #1119232
11/25/11 12:00 PM
11/25/11 12:00 PM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
I think I'm gonna paint mine with semi gloss black engine paint.
Re: K-FRAME PAINT??? [Re: rallye73] #1119233
11/25/11 07:38 PM
11/25/11 07:38 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
I went t the local Menards and bought a gallon can of Alykyd Enamel. Its a direct to metal paint.
I rolled it on with a foam roller, and touched up the small areas with foam pads.
Hard to tell it wasnt sprayed.
I have used this type of paint for many things, picinic tables (5 years outside and still going),
canoes, and most recently on forklifts in a meat plant, where the trucks are subjected to high temp high pressure sanitizer/water solutions. ITs the longest lasting stuff fo that application.
Re: K-FRAME PAINT??? [Re: NTOLERANCE] #1119234
11/27/11 01:13 AM
11/27/11 01:13 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Doc,thanks for that info!...I'll check into it! Gotta find a Menard's around here somewhere! I think there might be one near Flint...an hour away!
