cuda dash #1118734
11/21/11 07:25 PM
11/21/11 07:25 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Ok got dash out of 70 Cuda non rally( 7grand tack) The old( wow what a mess of wires,) Question is Where do you start on resto of it, New Wiring, do it yourself or send it out? wiring looks good but some of the plugs etc have that old green to them, Thanks inadvance Up here in Ontario Canada
Re: cuda dash [Re: 300_dup5] #1118735
11/21/11 10:16 PM
11/21/11 10:16 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Take LOTS of pictures from all angles and all areas.
Tear it down , taking LOTS of notes as you take it apart for things to pay close attention to while it's apart.
I glass bead the bare frame to repaint it. Then dis-assemble the main cluster and switches as far down as reasonably required +/or your able to .
test everything while it's apart, if in doubt ask questions.
For gauge cluster faces, I highly recomend Premium Dash Decals
ps- you can build a frame out of 2x4's to make a stand that is so much easier than rolling it around on a workbench
Re: cuda dash [Re: 300_dup5] #1118736
11/21/11 10:24 PM
11/21/11 10:24 PM
Houston Texas
PAINT IT BLACK Offline
Got a CHIP on my shoulder
Houston Texas
Douse it with gasoline. Throw a match on it... then check back with us and we'll line you out.
I know, I'm a bunch of help...
Your wires probably aren't as bad as they seem. They clean up reall nice with a non-polar solvent like laquer thinner after a quick and light pass with a soapy sponge (don't hose it down). Just go over it, make sure your contacts are as clean as possible (wire brush if possible). After cleaning up wires and bead blasting/ painting the frame, there's not that much to it except patience. Collor Correct sells the proper suede finish paint.
If you really do get frustrated, feel free to set it on fire and start over.
Re: cuda dash [Re: PAINT IT BLACK] #1118737
11/21/11 10:42 PM
11/21/11 10:42 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
The last thing I would want is a fire. Gas or not. How about a new dash harness. I,m going with a MSD set up . Doing a nut and bolt resto Thanks
Re: cuda dash [Re: 300_dup5] #1118738
11/21/11 11:45 PM
11/21/11 11:45 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Can you ellaborate on "non rallye ( 7grand tack)"? Non-rally clusters didn't have a tach.
Re: cuda dash [Re: lahatte] #1118739
11/22/11 07:55 AM
11/22/11 07:55 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
It has a tach. I thought rally ones where 8 Am I wrong. Thanks
Re: cuda dash [Re: PAINT IT BLACK] #1118740
11/22/11 09:40 AM
11/22/11 09:40 AM
STL
cdstl Offline
cdstl  Offline
STL
Do you have a link for these guys?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: cuda dash [Re: 300_dup5] #1118741
11/22/11 10:08 AM
11/22/11 10:08 AM
SC
Cooda Offline
Cooda  Offline
SC
This is a Ralley dash....if I remember correctly the '72-'74 ralley dashes had the tach that only went to 7 grand.
Non-ralley, or standard dash looks like this, with no tach....
Re: cuda dash [Re: Cooda] #1118742
11/22/11 11:24 AM
11/22/11 11:24 AM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
I guess i have a 72 rallye then Its the same as your pic except reset knobs on clock and speedo on within the gauge (not on exterior ) ?
Re: cuda dash [Re: 300_dup5] #1118743
11/22/11 01:00 PM
11/22/11 01:00 PM
SC
Cooda Offline
Cooda  Offline
SC
That is correct, '72 and up the reset knobs go through the clear plastic on the gauges.
Re: cuda dash [Re: Cooda] #1118744
11/22/11 02:59 PM
11/22/11 02:59 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks Cooda With that in mine would i be better to get a correct 70 with 8 tach,, although mine is in good shape Thoughts all Thanks Again
Re: cuda dash [Re: 300_dup5] #1118745
11/22/11 03:08 PM
11/22/11 03:08 PM
SC
Cooda Offline
Cooda  Offline
SC
Depends on what you are looking for as an end result. If you leave the 72-74 gauges in a 70 or 71 car...be warned that everyone that knows the difference will let you know about it at the car shows.
The 70-71 gauges will always be worth more money...
Re: cuda dash [Re: 300_dup5] #1118746
11/22/11 03:18 PM
11/22/11 03:18 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Im sure you could re-use the old dash harnes but remember, it the hub for the whole cars electronics so check it carefully for high resistance/rotted tarnished connectors and rotted fuse holders in the fuse block. I would unrap the harness to check the wires that run to the ampmeter to make sure the insulation is not melted anyware under the harness wrapping. These days a new harness cost $$$$ but on my Challenger I replaced ALL the wiring (back befor year one hooked up with M&H)and the electronics work much better then my other car with a re-used harness. I use the 7220 rustoleum black Texture paint for the dash and the NEW woodgrain besels (NOT the decals )from Performance Car Graphics. I also used Redline guage works and had the ampmeter converted to a voltmeter, VDO tach,Quartz clock,solid state volt limiter,and had all the orang needles repainted. My e-body guage faces were perfect so no work was done to them. By the time I was done with a new pad redon (just dashes)I had over $2500 in my Challenger R/t dash. I adds up fast !
Re: cuda dash [Re: THESHAKERPROJECT] #1118747
11/22/11 04:31 PM
11/22/11 04:31 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks. Although this car will be AAR clone, I am doing a nut and bolt resto, and I,m in no rush. Maybe I,ll look for a 70-71 cluster. ??? Any leads on one. I don,t go to many shows and really don,t give a hoot about people picking things apart. Thoughts on that Idea Thanks again
Re: cuda dash [Re: 300_dup5] #1118748
11/22/11 08:44 PM
11/22/11 08:44 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
A lot of people use the later rally clusters in the 1970-71 cars. So since it isn't correct, it just depends on how "correct" you want to make the build. If it doesn't bother you that some people will notice that the cluster is not correct for that year, then go with it.
Re: cuda dash [Re: lahatte] #1118749
11/22/11 11:46 PM
11/22/11 11:46 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Ya I think i,ll use the one i have it,s in good shape I know i can get the real deal ( gauge cluster only) that has been redone and tested by some firm in the states for $ 400.00 Though ????
Re: cuda dash [Re: cdstl] #1118750
11/23/11 10:23 AM
11/23/11 10:23 AM
Houston Texas
Houston Texas
Used to be called Mopaint. Phone # is 732-846-1044
