4.310 bore X 4.500 stroke combos. #1118396
11/21/11 03:42 PM
11/21/11 03:42 PM
Lost in Pooler, GA
Gumbydammit Offline OP
Lost in Pooler, GA
I have a buddy with a new 4.310 bore KB water block. He is wondering if a 4.500 stroke will cause only make torque down low and run out of steam at the top end of the track. I don't think so.
It is a Hemi with a good set of heads. T&D rockers, LSM cam, yadda yadda, all the good stuff. It is just getting a new rotating assembly.
If you had to put a rotating assy in a 4.310 bore block that was going to go in a 3400# drag car with a glide and up to 300HP of nitrous, which stroke would you go with? I know what I think. . .
I'm Gumby dammit!
Re: 4.310 bore X 4.500 stroke combos. [Re: Gumbydammit] #1118397
11/21/11 04:05 PM
11/21/11 04:05 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
It isn't just the heads that dictate how well an engine holds on. The induction (intake/carbs) is CRITICAL.
Re: 4.310 bore X 4.500 stroke combos. [Re: Gumbydammit] #1118398
11/21/11 04:06 PM
11/21/11 04:06 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Build it, it will run great. If it has too much TQ down low and not enough at the top end swap rear gears.
Re: 4.310 bore X 4.500 stroke combos. [Re: HotRodDave] #1118399
11/21/11 04:15 PM
11/21/11 04:15 PM
Lost in Pooler, GA
Lost in Pooler, GA
YUP, That's what I'm sayin. It has the big port Ray Barton Dominator intake with a good HP dominator. The heads are well - worked older KB heads and the motor made power by accident with a little less stroke. Long story short, with all the engine had going against it, it still ran good. Now, with all the right parts, and proper assembly, it should be an animal!
I'm Gumby dammit!
Re: 4.310 bore X 4.500 stroke combos. [Re: Gumbydammit] #1118400
11/22/11 04:09 AM
11/22/11 04:09 AM
gregsdart Offline
gregsdart  Offline
Re: 4.310 bore X 4.500 stroke combos. [Re: gregsdart] #1118401
11/25/11 09:34 AM
11/25/11 09:34 AM
Smithfield, Rhode Island
Mulehead Offline
Mulehead  Offline
There a few Moparts members that are running 4.44 x 4.500. Have not hear from them.
Ain't nuthin like a HEMI !
Re: 4.310 bore X 4.500 stroke combos. [Re: Mulehead] #1118402
11/25/11 11:55 AM
11/25/11 11:55 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
When I first built my currant hemi for the 1st time about 11 years ago,I already had a 4.5 stroke Bryant crank.The builder {RIP Lou Vignogna} wanted me to go right to a 4.5 bore to be "square".I insisted on a smaller bore of 4.310 so I would have room for NEXT TIME I'm on the 3rd next time and now reside at 4.391.This time I got a set of SV1's and sold them little 750's that kept me at 4/5 lbs of boost and 10.ohs and a 9.93 best on pump gas.By the way,my junk is 3850 with me & a full tank of gas.Got on the engine dyno last month and pump gas,28* timing and 4 lbs of boost netted 740 HP.On race gas & 10 lbs pushed it to over 900 hp with 850 ft lbs of torque @ 4900 RPM.Not too shabby considering I could not use my carbs or headers
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 4.310 bore X 4.500 stroke combos. [Re: hemi-itis] #1118403
01/29/12 11:03 AM
01/29/12 11:03 AM
Mulehead Offline
Mulehead  Offline
With a small bore and lone stork with a blower on top will work well.This motor n/a I think will run out of air.I;m thinking of going back to 4.310x4.375 that made hp to and proven motor ( old motor )Now having hard time getting Callies magnum 4.375.Your thoughts ??
Re: 4.310 bore X 4.500 stroke combos. [Re: Mulehead] #1118404
01/29/12 11:46 AM
01/29/12 11:46 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Food for thought.... The combustion chamber of a OEM Hemi head has a diameter of 4.310. Sounds like a good match to me.
Its not an Oldsmobile, so its not limited to only making torque
With ported heads and a proper cam, you can make that a motor build power to at least 6500-7000rpm. A lot of N/A and Nitrous Promod motors are under-square.
Re: 4.310 bore X 4.500 stroke combos. [Re: Defbob] #1118405
01/29/12 11:52 AM
01/29/12 11:52 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
DTHemi's 655ci Hemi has a 4.56" bore and a 5" stroke. And I doubt he would ever let an engine he built, peak under 7000rpm.
Re: 4.310 bore X 4.500 stroke combos. [Re: Gumbydammit] #1118406
01/29/12 12:16 PM
01/29/12 12:16 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
I agree with Hemi-itis, but personally would do a turbo with EFI. I would not do the nitrous routine again, too tough to manage and hard on parts.
8.30's @3400 lbs
Re: 4.310 bore X 4.500 stroke combos. [Re: hemi-itis] #1118407
01/29/12 01:44 PM
01/29/12 01:44 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
isn't boost great???
Coming soon!!!!
Re: 4.310 bore X 4.500 stroke combos. [Re: Mr.Yuck] #1118408
01/29/12 02:18 PM
01/29/12 02:18 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Bore size is simply not as critical as a head flow limitation on a Hemi, mainly because the valve motions angle toward the bore centers as they open, alleiviating much of the shouding that becomes an issue with a Wedge configuraion. On a wedge the valve action is straight and parallel to eachother, which means the edge of the valve stays at a fixed distance from the bore, with a hemi, the more you lift the valve the further away it moves away from the bore and closer to the center of the hole.
Sounds like a great combo to me
WIZE
In Car:
Re: 4.310 bore X 4.500 stroke combos. [Re: Streetwize] #1118409
01/29/12 03:25 PM
01/29/12 03:25 PM
Mulehead Offline
Mulehead  Offline
More information on Hemi,Alcohol head,426-3 intake,1050 dominator,Lsm cam 840in 806ex
Re: 4.310 bore X 4.500 stroke combos. [Re: Mr.Yuck] #1118410
01/30/12 12:39 AM
01/30/12 12:39 AM
hemi-itis Offline
hemi-itis  Offline
It's the best bolt on I've EVER done
