4.310 bore X 4.500 stroke combos.
#1118396
11/21/11 03:42 PM
11/21/11 03:42 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
I have a buddy with a new 4.310 bore KB water block. He is wondering if a 4.500 stroke will cause only make torque down low and run out of steam at the top end of the track. I don't think so.
It is a Hemi with a good set of heads. T&D rockers, LSM cam, yadda yadda, all the good stuff. It is just getting a new rotating assembly.
If you had to put a rotating assy in a 4.310 bore block that was going to go in a 3400# drag car with a glide and up to 300HP of nitrous, which stroke would you go with? I know what I think. . .
I'm Gumby dammit!
Re: 4.310 bore X 4.500 stroke combos.
[Re: Gumbydammit]
#1118397
11/21/11 04:05 PM
11/21/11 04:05 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
It isn't just the heads that dictate how well an engine holds on. The induction (intake/carbs) is CRITICAL.
[Re: Gumbydammit]
#1118398
11/21/11 04:06 PM
11/21/11 04:06 PM
Posts: 12,423 Kalispell Mt.
HotRodDave
Kalispell Mt.
Build it, it will run great. If it has too much TQ down low and not enough at the top end swap rear gears.
[Re: HotRodDave]
#1118399
11/21/11 04:15 PM
11/21/11 04:15 PM
Gumbydammit
Lost in Pooler, GA
YUP, That's what I'm sayin. It has the big port Ray Barton Dominator intake with a good HP dominator. The heads are well - worked older KB heads and the motor made power by accident with a little less stroke. Long story short, with all the engine had going against it, it still ran good. Now, with all the right parts, and proper assembly, it should be an animal!
I'm Gumby dammit!
[Re: hemi-itis]
#1118403
01/29/12 11:03 AM
01/29/12 11:03 AM
Posts: 253 Smithfield, Rhode Island
Mulehead
With a small bore and lone stork with a blower on top will work well.This motor n/a I think will run out of air.I;m thinking of going back to 4.310x4.375 that made hp to and proven motor ( old motor )Now having hard time getting Callies magnum 4.375.Your thoughts ??
Ain't nuthin like a HEMI !
[Re: Mulehead]
#1118404
01/29/12 11:46 AM
01/29/12 11:46 AM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
Food for thought.... The combustion chamber of a OEM Hemi head has a diameter of 4.310. Sounds like a good match to me. Its not an Oldsmobile, so its not limited to only making torque With ported heads and a proper cam, you can make that a motor build power to at least 6500-7000rpm. A lot of N/A and Nitrous Promod motors are under-square.
[Re: Gumbydammit]
#1118406
01/29/12 12:16 PM
01/29/12 12:16 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I agree with Hemi-itis, but personally would do a turbo with EFI. I would not do the nitrous routine again, too tough to manage and hard on parts.
8.30's @3400 lbs
[Re: hemi-itis]
#1118407
01/29/12 01:44 PM
01/29/12 01:44 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
When I first built my currant hemi for the 1st time about 11 years ago,I already had a 4.5 stroke Bryant crank.The builder {RIP Lou Vignogna} wanted me to go right to a 4.5 bore to be "square".I insisted on a smaller bore of 4.310 so I would have room for NEXT TIME I'm on the 3rd next time and now reside at 4.391.This time I got a set of SV1's and sold them little 750's that kept me at 4/5 lbs of boost and 10.ohs and a 9.93 best on pump gas.By the way,my junk is 3850 with me & a full tank of gas.Got on the engine dyno last month and pump gas,28* timing and 4 lbs of boost netted 740 HP.On race gas & 10 lbs pushed it to over 900 hp with 850 ft lbs of torque @ 4900 RPM.Not too shabby considering I could not use my carbs or headers
isn't boost great???
