Indy CNC 295 SR or EZ Min Cross Section Area (MCSA)? #1118382
11/21/11 02:33 PM
11/21/11 02:33 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Anyone on here able to provide a fairly accurate Minimum Cross-Section Area (MCSA) measurement for an Indy SR or EZ w/ ICH's CNC 295 cc porting? I'm curious how it compares to my CNC-ported Victors that show pretty simmilar flow #s but "should" (based on not being taken out to Max Wedge-sized entries) have a bit better velocity.
FWIW, the MCSA I measured on the Victors yesterday is 3.05", although it gets quite a bit bigger as the runner opens up into the bowl over the short turn.
Re: Indy CNC 295 SR or EZ Min Cross Section Area (MCSA)? [Re: BradH] #1118383
11/21/11 02:40 PM
11/21/11 02:40 PM
SoCal
Brian Hafliger Offline
SoCal
Min. I belive on the 295 head is 2.8"
Brian Hafliger
Re: Indy CNC 295 SR or EZ Min Cross Section Area (MCSA)? [Re: Brian Hafliger] #1118384
11/21/11 02:44 PM
11/21/11 02:44 PM
BradH Offline OP
BradH  Offline OP
If you're correct, then so much for that "theory"...
Re: Indy CNC 295 SR or EZ Min Cross Section Area (MCSA)? [Re: BradH] #1118385
11/21/11 04:02 PM
11/21/11 04:02 PM
BradH Offline OP
BradH  Offline OP
While I'm on the subject, anyone know the same dimension for a Chapman 260cc Stage VI?
