how much oil do I really need? #1118199
11/21/11 09:47 AM
11/21/11 09:47 AM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
Is it necessary to have a "deep" or extra capacity oil pan?
My engine is a typical 408 sb with about 500 hp and will be a street/strip engine. I don't want a deep hanging oil pan, and I don't really want to spend $400-500 for a "road race" style pan with the baffles and all that.
Will a Milodon stock capacity pan with the internal baffles work for me?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: how much oil do I really need? [Re: 11secaarcuda] #1118200
11/21/11 11:06 AM
11/21/11 11:06 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
It's been my experience that long stints at highway speeds can suck the pan dry.......this was with a H.V. pump and stock pan.
Sustained elevated R.P.M.'s are the deal breaker here.
Re: how much oil do I really need? [Re: tubtar] #1118201
11/21/11 11:09 AM
11/21/11 11:09 AM
PA
moparacer Offline
moparacer  Offline
PA
The further you get the sump from that spinning crank the better off you will be...
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: how much oil do I really need? [Re: 11secaarcuda] #1118202
11/21/11 12:11 PM
11/21/11 12:11 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
My you need a deep pan with a HV oil pump. If you are running a stock or HP pump, then a windage try and stock pan can be used.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: how much oil do I really need? [Re: 11secaarcuda] #1118203
11/21/11 02:47 PM
11/21/11 02:47 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Lots of NHRA stockers running near or in the 9's with a stock pan, but are also using baffles, crank scrapers and mesh type windage trays. So no, it's not necessary to have a real deep pan; just get the oil back downstairs as fast as you can and away from or off the crank. I've heard over the years that many stocker guys toss the stock windage tray as it doesn't drain fast enough and instead use the mesh type. Grinding/smoothing drain back holes for casting flash and smoothing oil returns in the head and valley can't hurt either. A valley tray also helps keep the oil off the bottom of the intake and redirects any splash from the cam back downstairs.
Re: how much oil do I really need? [Re: Sixpak] #1118204
11/21/11 02:56 PM
11/21/11 02:56 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Have you ever asked the guys running those NHRA stockers how little oil they run in their engine? The answer might shock you.
Re: how much oil do I really need? [Re: Blues_Cuda] #1118205
11/21/11 03:05 PM
11/21/11 03:05 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah and the weight of the oil will shock you even more... But to eek out the last bit of horsepower they take chances... Do you really want to rebuild the bottom end after every race... I've never heard of an engine blowing up because it had to much oil unless it was some idiot that put eight quarts in a five quart pan... Put a pan designed for 7+ & run six...
Re: how much oil do I really need? [Re: Blues_Cuda] #1118206
11/21/11 03:21 PM
11/21/11 03:21 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Yea, and they do take chances but they can get away with running that small amount of oil and lighter oil because of all the other things they do to control the oil. There's also horsepower to be gained by not running too high oil pressures, and whether or not you really need a hi volume pump is also questionable. Will you suck the pan dry if all the oil gets pumped upstairs? The oil could be wrapped around the crank due to windage or stuck in the valley or heads. There are things learned from racing that can be applied to the street; some tricks are best left for the race track due to their increased maintenance for eking out every last bit of horsepower.
Re: how much oil do I really need? [Re: 11secaarcuda] #1118207
11/21/11 03:24 PM
11/21/11 03:24 PM
gregsdart Offline
gregsdart  Offline
Who built the motor and what do they recommend? First thing I see is 500 hp and 408 cubes. That tells me you are going to spin this motor up some.
Not being familiar with small blocks, my first question would be what oil viscosity you are going to run. Anything higher than stock, combined with lose bearing clearances is going to require more capacity. Actually either will change the situation, engine clearances being the bigger problem. It would be great if you could have some capacity added by adding a kick out on the pan if you have room. Skid plates could be used to protect a deeper pan if you decide you need more clearance.
Re: how much oil do I really need? [Re: gregsdart] #1118208
11/21/11 05:03 PM
11/21/11 05:03 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Find a bushing that will thread into your oil pan plug hole and put a 3/8 threaded hose barb on the bushing.... Buy some clear plastic 3/8 hose and run it from the hose barb up the back of the pan up over the trans and secure it... fill the oil to the proper level & have someone run the engine in park... you will see how much oil is left in the pan @ different rpms.... If you run a HV pump it may shock you
Re: how much oil do I really need? [Re: 1_WILD_RT] #1118209
11/21/11 05:24 PM
11/21/11 05:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I heard when they are going for a record they will really push it for every ounce of power. But I dont think they run it that low all of the time ? At least I would only push it that far when trying to set a record. Ron
Re: how much oil do I really need? [Re: 383man] #1118210
11/21/11 05:32 PM
11/21/11 05:32 PM
organ
maximum entropy Offline
organ
and as far as the "high volume" debate goes, the high volume pump is not going to deliver more volume unless the engine needs it. at a given pressure, low and high volume pumps will deliver the same amount of oil (assuming the low volume pump can keep up with demand).
Re: how much oil do I really need? [Re: maximum entropy] #1118211
11/21/11 05:48 PM
11/21/11 05:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
A typical Mopar HV rotor is 20 or 25% larger (taller) so on every revolution is going to displace (move) that much more oil. I understand that the bypass spring can come into play as far as demand, I'm sure that's what you're referring to
In a fluid circuit inside the motor you have controlled bleeds (main bearings, rod bearings, valvetrain rocker shafts, lifter galley, etc) which correspond to volume losses and pressure drops which accumulate back into the sump. Increased bearing diameters increase the p losses (controlled bleeds) in the system. There are seriesed (rear to front on a sb crank and front to rear on a BB crank) and parrallel pressure drops along the way. When RPM demands and bleed rates exceed delivered rate of the supply is when you start getting into problems.And in series losses (by definition) the next one in line sees less supply pressure than the one that fed it, so in a way of thinking about it...'adequate' volume and pressure really refers to adequate minimums to the last pieces in line...i.e, furthest from the supply
Porting the passageways (EX: on a SB I always open the #5 main and the pump passage to 1/2") reduces restrictions and pressure drops before the first controlled bleed and porting the pump itself makes it work more efficiently (just like porting the head of an engine) under high demands.
Returning oil to the sump more efficiently is one of the main ways racers can get by with reducing sump volume, thinner oil obviously bleeds back faster as well. Once W2's came out the RPM's went way up and we soon discovered that windage trays on small blocks can cuase issues as they typically didn't have sufficeint baffling to retern oil to the sump...and as a relult oil would puddle in the shelf for the crank to dip the counterwieghts in and became more of a problem than the roping problem they were designed to relieve. We tossed them and our et's dropped.
WIZE
In Car:
Re: how much oil do I really need? [Re: Streetwize] #1118212
11/21/11 06:10 PM
11/21/11 06:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Re: how much oil do I really need? [Re: 11secaarcuda] #1118213
11/21/11 06:13 PM
11/21/11 06:13 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been racing w/6 quarts in an 8 qt. pan for years up to 7500 rpm`s and my bearings looked real good after 7+ years of street/strip bashing and that`s w/rpm heads which collect all kinds of oil in the heads.
Re: how much oil do I really need? [Re: tubtar] #1118214
11/21/11 07:06 PM
11/21/11 07:06 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
