VIN Tag removal #111816
08/28/08 08:12 PM
08/28/08 08:12 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I have removed the dash and dash pad from my 70 Challenger getting ready to ship / deliver to UR in El Paso.
What is the easiest way to romove the rivets from the dash pad frame / VIN tag? I started to drill the VIN tag side, but noticed it may be easier to grind off the back of the rivet?
I have drilled out many rivets over the years.......I just do not want to damage anything!
Re: VIN Tag removal [Re: jsully] #111817
08/28/08 08:15 PM
08/28/08 08:15 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Why do you want to remove it?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: VIN Tag removal [Re: BloFish] #111818
08/28/08 08:17 PM
08/28/08 08:17 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I cannot ship it with the dash pad
Re: VIN Tag removal [Re: jsully] #111819
08/28/08 08:19 PM
08/28/08 08:19 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
why?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: VIN Tag removal [Re: BloFish] #111820
08/28/08 08:39 PM
08/28/08 08:39 PM
Kirkland, Washington
Pacnorthcuda Offline
uh, because if he's sending it out for resto, he won't get the tag back.
I ground the back side off, You don't want to damage the 'rosettes' if you're going to reuse.
I glued mine back on. Looks perfect, functions perfect, good enough for me.
Re: VIN Tag removal [Re: Pacnorthcuda] #111821
08/28/08 09:04 PM
08/28/08 09:04 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
Perfect! Thanks, I will go grind them off from the back.
(I do not have another good answer as to why I must remove the tag--Arizona is picky about dash VIN tag # matching the VIN tag # on the drivers door or they will not 'verify' the odometer reading- so I am safekeeping the tag while it goes to get resto'ed)
Re: VIN Tag removal [Re: Pacnorthcuda] #111822
08/28/08 10:43 PM
08/28/08 10:43 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Uh, that's why I was asking.
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: VIN Tag removal [Re: BloFish] #111823
08/28/08 10:45 PM
08/28/08 10:45 PM
and now you know!
Re: VIN Tag removal [Re: Pacnorthcuda] #111824
08/28/08 10:58 PM
08/28/08 10:58 PM
Arizona
jsully Offline OP
jsully  Offline OP
Arizona
I just removed the tag. I ground the backs of the rivets flush and then drilled the back (slightly) with a 1/4" bit to free them (they are countersunk).
Thanks for the info!
