470 Stroker pushrod length
#1118115
11/21/11 01:56 AM
11/21/11 01:56 AM
Posts: 322 San Diego, CA, United States
Texas_Charger
Hello all, I dont mean to open a can of worms regarding Stealth heads because I understand some here don't prefer them. However, many have used them with good results. I am building a 470 Stroker, with a standard 400 block (no decking or milling done to the block or heads), Stealth CNC ported aluminum heads, and stealth rockers (1.6:1 ratio) and these valve springs: http://www.hughesengines.com/Index/produ...mp;partid=10270I am wondering if I can go with stock-length pushrods, or should I order custom length. Does anyone have this combination or one similar? Thanks in advance
1971 Dodge Charger SE 470/727/3.91 Suregrip 2016 Dodge Challenger Hellcat, 6-speed 1980 Pontiac Trans Am, Y84, WS6 2002 Ram 2500 Cummins/6-speed/2WD/QC 1971 Ford F-350 Ranger
Re: 470 Stroker pushrod length
[Re: 383man]
#1118118
11/21/11 11:49 AM
11/21/11 11:49 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
yup. just something as simple as changing to a new cam with higher lift... the base circle could be lower than a stock cam, giving more net lift on a similar sized lobe (gotta keep it small enough to fit through the cam tunnel!!) and that lower base circle means the lifter drops lower and you need either adjustable rockers or a longer pushrod to make up the difference.
Jegs/Mancini/etc. have adjustable threaded "checker" pushrods for about $10. pick one up, mock up your valve train, then measure how long of a rod you need and order a set. they aren't that expensive
**Photobucket sucks**
[Re: GomangoCuda]
#1118121
11/21/11 03:12 PM
11/21/11 03:12 PM
Texas_Charger
Thanks guys, I plan on getting a pushrod length checker so I can figure out what length to get. Any idea on a ball park length I should order? (summit sells them in a variety of size ranges and I dont have the stock pushrods here to check)
