SFI Hemi Flywheel needed for street car? #1117977
11/20/11 08:27 PM
11/20/11 08:27 PM
USA
SSAAHemiFan Offline OP
USA
Want to know if I should upgrade to a SFI steel flywheel over a stock one? - Street car but will be beat on occasionally - have a lakewood shield and block plate that will be used.
I have never heard of a factory street hemi flywheel coming apart( like Chevy's did) BUT I wasn't around when these cars were built.
Are the Hemi flywheel's better quality than a 383 or 440 flywheel
Thanks !
Re: SFI Hemi Flywheel needed for street car? [Re: SSAAHemiFan] #1117978
11/20/11 08:39 PM
11/20/11 08:39 PM
Indiana
maxie Offline
maxie  Offline
Indiana
I have a mcleod flywheel behind my hemi. I get all my 4 speed stuff from Brewers. Give them a shout.
Re: SFI Hemi Flywheel needed for street car? [Re: maxie] #1117979
11/20/11 08:58 PM
11/20/11 08:58 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I used to come off the line, side-stepping the clutch at over 5500 rpms on a low 11 second RoadRunner for years with a stock flywheel with no problem. Never heard of one coming apart. If you are just going to beat on it on the street once in a while or even with slicks at the track infrequently, I would not worry about it one bit...even if it has some crazing in it.
Re: SFI Hemi Flywheel needed for street car? [Re: SSAAHemiFan] #1117980
11/20/11 10:37 PM
11/20/11 10:37 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
I have a clutch and flywheel book that shows a list of engines that have "OEM high burst strength flywheels". They show the the Hemi as having a cast iron alloy flywheel, and some bb chevy and Boss 302/429 having Nodular cast iron flywheels. It also says engine not listed don't have high burst strength flywheels.
