Re: cleaning up / paint surface rust frame rails and floorp
[Re: 340duster340]
#1117964
11/21/11 09:01 PM
11/21/11 09:01 PM
Posts: 1,572 Jacksonville Florida
elitecustombody
I'd advise against wire brush,unless you will be using it only to remove and loose paint,e.t.c.. If you want a better results,use D/A sander to remove surface rust, because wirebrush will remove loose stuff and glaze up the surface,trapping the rest of rust. But for best results,blasting is the only way to get rid of it all. Picklex,Ospho type stuff does it's job just fine, but follow instructions if you want lasting results.
[Re: elitecustombody]
#1117967
11/21/11 10:53 PM
11/21/11 10:53 PM
Challenger 1
Cincinnati, Ohio
[Re: Challenger 1]
#1117968
11/21/11 11:32 PM
11/21/11 11:32 PM
Posts: 4,323 NY NY
340duster340
NY NY
Thanks for the feedback guys.i will be doing this in my back. I have a bucket blaster but since I will be working inside I didn't want to make a huge mess. What grit do you recommend for the DA sander?
1966 Dart GT
...down to only 1 mopar for the first time in 15 years!
#1117970
11/22/11 10:08 AM
11/22/11 10:08 AM
Posts: 4,323 NY NY
340duster340
NY NY
For blasting what do you use to plug the holes in the frame rails?
1966 Dart GT
