cleaning up / paint surface rust frame rails and floorp #1117962
11/20/11 07:59 PM
11/20/11 07:59 PM
NY NY
3
340duster340 Offline OP
NY NY
i need to clean up the surface rust and scale from my frame rails and floor pans
my main goal is just to stop it from getting worse + add protection for driving use.
i was going to wire wheel clean it, and then paint with a good primer/sealer and then top coat.
suggestions on materials paint wise? is it worth going nuts with an acid neutralizer or would a converter-type paint work fine.
Re: cleaning up / paint surface rust frame rails and floorp [Re: 340duster340] #1117963
11/21/11 02:24 AM
11/21/11 02:24 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Have you looked at Rust Bullet?
Re: cleaning up / paint surface rust frame rails and floorp [Re: 340duster340] #1117964
11/21/11 09:01 PM
11/21/11 09:01 PM
Jacksonville Florida
elitecustombody Offline
I'd advise against wire brush,unless you will be using it only to remove and loose paint,e.t.c.. If you want a better results,use D/A sander to remove surface rust, because wirebrush will remove loose stuff and glaze up the surface,trapping the rest of rust. But for best results,blasting is the only way to get rid of it all. Picklex,Ospho type stuff does it's job just fine, but follow instructions if you want lasting results.
Re: cleaning up / paint surface rust frame rails and floorp [Re: 340duster340] #1117965
11/21/11 09:37 PM
11/21/11 09:37 PM
Il
1ol74charger4me Offline
Il
Are you doing this on a rotisseree or on your back? Its hard to do a thorough job with anything less than a sandblaster. Black stripper discs work better than wirewheels but they can get pricey because they wear fast.
Re: cleaning up / paint surface rust frame rails and floorp [Re: 1ol74charger4me] #1117966
11/21/11 09:39 PM
11/21/11 09:39 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ospho, spray it on and rinse it off. Tim
Re: cleaning up / paint surface rust frame rails and floorp [Re: elitecustombody] #1117967
11/21/11 10:53 PM
11/21/11 10:53 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: cleaning up / paint surface rust frame rails and floorp [Re: Challenger 1] #1117968
11/21/11 11:32 PM
11/21/11 11:32 PM
NY NY
3
NY NY
Thanks for the feedback guys.i will be doing this in my back. I have a bucket blaster but since I will be working inside I didn't want to make a huge mess. What grit do you recommend for the DA sander?
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: cleaning up / paint surface rust frame rails and floorp [Re: 340duster340] #1117969
11/22/11 12:52 AM
11/22/11 12:52 AM
80,I wouldn't use finer than 120. You can get plastic drop cloth at Home Depot and make a temporary blasting room, just make sure to wear respirator.
Re: cleaning up / paint surface rust frame rails and floorp [Re: elitecustombody] #1117970
11/22/11 10:08 AM
11/22/11 10:08 AM
NY NY
3
NY NY
For blasting what do you use to plug the holes in the frame rails?
Re: cleaning up / paint surface rust frame rails and floorp [Re: 340duster340] #1117971
11/22/11 10:44 AM
11/22/11 10:44 AM
Cincinnati, Ohio
Cincinnati, Ohio
Blasting should never be done unless the car is stripped bare. Not something you want to do with it together.
Re: cleaning up / paint surface rust frame rails and floorp [Re: Challenger 1] #1117972
11/22/11 11:29 PM
11/22/11 11:29 PM
NY NY
3
NY NY
yeah but i have done before in controlled environments...i just don't want to fill the rail with sand.
