Torsion bars #1117176
11/19/11 09:13 PM
11/19/11 09:13 PM
GoDartGo Offline OP
GoDartGo  Offline OP
I'm replacing a pitted T-bar with one I've had
from a parted Duster.
Question is does the CTJ/893L go to the front
or to the back?
Re: Torsion bars [Re: GoDartGo] #1117177
11/19/11 09:36 PM
11/19/11 09:36 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
back
Re: Torsion bars [Re: Wedgeman] #1117178
11/19/11 10:14 PM
11/19/11 10:14 PM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
don't think it makes any difference, but I always put it in the back so it can be seen.
Steve
Re: Torsion bars [Re: Strawdawg] #1117179
11/19/11 11:24 PM
11/19/11 11:24 PM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
Re: Torsion bars [Re: kentj340] #1117180
11/19/11 11:27 PM
11/19/11 11:27 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Doesn't make any difference.....
Re: Torsion bars [Re: Jim_Lusk] #1117181
11/20/11 12:17 AM
11/20/11 12:17 AM
GoDartGo Offline OP
GoDartGo  Offline OP
THANKS
Re: Torsion bars [Re: kentj340] #1117182
11/20/11 12:39 AM
11/20/11 12:39 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
See the Tech Archive here:
http://www.moparts.org/Tech/Archive/susp/7.html
I just looked up the tool for TB removal that was shared in the archive. In the archive it appeared to be a $70-$80 tool, but appears that it has gone up to $350-400 now - inflation or am I missing something?
-chad
Re: Torsion bars [Re: ramman5600] #1117183
11/20/11 12:58 AM
11/20/11 12:58 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
has anyone used the Mancini racing tool?
http://chucker54.stores.yahoo.net/tobarreabceb.html
-C
Re: Torsion bars [Re: ramman5600] #1117184
11/20/11 01:27 AM
11/20/11 01:27 AM
Eden, Texas
Strawdawg Offline
Strawdawg  Offline
Eden, Texas
If you think you need a tool, you can cut a couple of pieces of 2x4 and clamp them around the tb with a some bolts.
Normally, I take the nut off the strut rod and loosen the bolt on the control arm.
Remove the retaining clip on the back end of the tb, then tap the control arm backward at the wheel end and beside the control arm bolt-which will normally push the tb out of its socket...then tap the arm forward and that should remove it from the tb on the front end. Putting a piece of wood on the arm where you are going to hit it will stop from scarring the paint.
Steve
Re: Torsion bars [Re: Strawdawg] #1117185
11/20/11 01:46 AM
11/20/11 01:46 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
The tool you clamp on from Mancini works well..however I suggest you get some grade 8 bolts to replace the ones that came with it. Especially if you use it a lot...those 1/4 inch bolts don't last long.
Maynard
Re: Torsion bars [Re: DartGTS] #1117186
11/20/11 02:27 AM
11/20/11 02:27 AM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Hello:
Maynard
Still should be a whole lot cheaper than the Miller tool piece even if I have to buy the extra bolts.
Re: Torsion bars [Re: ramman5600] #1117187
11/20/11 02:51 AM
11/20/11 02:51 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
a large pair of Vice Grips and 2 halves of the proper size tubeing will work just as well as a 350 $$ tool..
I am truckless..
Re: Torsion bars [Re: 340SHORTY] #1117188
11/20/11 03:04 AM
11/20/11 03:04 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
Bought mine from other source several years ago ... think I paid $35 or $40 for it...for $350 i'd expect someone to come with the tool and do it for me...LOL
Maynard
