BB Rear Main Seal #1116766
11/19/11 10:49 AM
11/19/11 10:49 AM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Guys,
Can the rear main seal be changed with the motor in the car? Motor is a BB400 with 727 auto tranny. The oil pan and steering linkage are dropped...
Thanks!!
Re: BB Rear Main Seal [Re: cjskotni] #1116767
11/19/11 10:57 AM
11/19/11 10:57 AM
yes. Might google "moparts rear seal issues"
Re: BB Rear Main Seal [Re: RapidRobert] #1116768
11/19/11 11:00 AM
11/19/11 11:00 AM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
yes again, i have done it on big and small blocks.
Re: BB Rear Main Seal [Re: 65rbdodge] #1116769
11/19/11 03:07 PM
11/19/11 03:07 PM
North Carolina
cjskotni Offline OP
cjskotni  Offline OP
North Carolina
Ok I went ahead and got the Fel Pro rubber set. Any suggestions as to which sealant to use (if any) to make sure it's sealed up nice 'n good?
Thanks!!
Re: BB Rear Main Seal [Re: cjskotni] #1116770
11/19/11 03:53 PM
11/19/11 03:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I suggest offsetting the seal in the retainer and block at least a quarter of an inch so that the parting line of the seal and retainer are in a different position.
Re: BB Rear Main Seal [Re: MoparforLife] #1116771
11/19/11 04:27 PM
11/19/11 04:27 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
Is your 400 leaking oil from the main seal? Mine is. I remember hearing that many people put the seal in wrong, what is the trick?
Re: BB Rear Main Seal [Re: cjskotni] #1116772
11/19/11 08:17 PM
11/19/11 08:17 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i put a rear main seal in my 68'dodge coronet, 440/727, i could not get the rubber seals to work, i had to wind up using the old rope seal, it work fine, i had to drop the center link to get the oil pan to come out.
Re: BB Rear Main Seal [Re: cornet684me] #1116773
11/19/11 09:25 PM
11/19/11 09:25 PM
Upper Midwest
Upper Midwest
Lip toward the inside (oil side) of the pan <-} So that any oil or internal pressures push the lips outward to contribute to a better seal.
