1970 CUDA Tail light wiring harness - couple questions. #1116177
11/18/11 01:21 PM
11/18/11 01:21 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
1st - There is a ground wire that is not part of the harness and it was removed from the drivers side corner of the lamp assembly. Which bolt is it supposed to be attached to? Anyone have any pics or factory diagrams?
2nd - Is there a supplier of the harness "covering"? I don't really need a new harness especially since I read that the sockets are different on the aftermarket harnesses... its just that mine looks a little ratty.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116178
11/18/11 01:49 PM
11/18/11 01:49 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Part of the covering on my original harness was like new...the part that was protected by the rocker guard. Is it possible to move the good section of the covering to the trunk area?
Someone was recovering original harnesses at one time. I don't know if they still are.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116179
11/18/11 06:41 PM
11/18/11 06:41 PM
middle of the country
aar1 Offline
aar1  Offline
the trunk harness has a cloth type of wrapping, doesn't it? Not sure where you can get any of that. The wiring harness sold by Year One (made by M&H) is very good. Correct wiring, sockets and wrapping.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: aar1] #1116180
11/18/11 08:04 PM
11/18/11 08:04 PM
Richmond, VA
rayztoy Offline
rayztoy  Offline
Richmond, VA
Evans Wiring Harnesses can wrap your harness for you. Contact info is http://www.evanswiring.com/ or 814-864-2622 or rbevans7@aol.com
Talk to Bill, as he is very knowlegable. They do a GREAT job!
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: aar1] #1116181
11/18/11 09:58 PM
11/18/11 09:58 PM
California
1970mopar Offline
1970mopar  Offline
California
the original trunk wrapping is a cotton weave if I recall. I believe M & H can re-wrap your original harness if you call them directly.
The M&H repro harnesses are good reproductions, however the sockets are not 100% correct for OE. The side marker and two of the four tail lamp sockets differ from originals in appearance by quite a bit.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116182
11/19/11 12:17 AM
11/19/11 12:17 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Hi Steve...Glad to see you're finally getting down to the final steps on the cuda...Here's the drawing you've requested...
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: screamindriver] #1116183
11/19/11 12:44 AM
11/19/11 12:44 AM
Houston Texas
Houston Texas
Thanks Colin. I found that pic searching through old Moparts posts. Exactly what I was looking for. It seems the passenger side tail light is grounded through the lock lever guard, but an additional ground strap was added to the drivers side to ground. Seems like a hokey afterthought. But that's what I have apparently devoted my life to... the hokey afterthought that is the '70 Barracuda!
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116184
11/19/11 12:55 AM
11/19/11 12:55 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
Will your vanity plate say, "HOKEY70"?
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: lahatte] #1116185
11/19/11 12:44 PM
11/19/11 12:44 PM
Houston Texas
Houston Texas
I tried that, but the DMV messed up and sent me HONKEY70.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116186
11/19/11 03:18 PM
11/19/11 03:18 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Here is how the original wire looked.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70440+6bbl] #1116187
11/19/11 03:22 PM
11/19/11 03:22 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Top view...
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70440+6bbl] #1116188
11/21/11 01:17 AM
11/21/11 01:17 AM
Houston Texas
Houston Texas
Perfect pics. Thanks.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116189
11/21/11 01:16 PM
11/21/11 01:16 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
was this ground wire on all cudas??? i have an early build 1970 and i restored the original wiring harness and never saw any wires routed to grounding the harness. no cuts or anything. very interesting info......
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70plymA34] #1116190
11/21/11 03:19 PM
11/21/11 03:19 PM
Houston Texas
Houston Texas
I am pretty certain your Cuda would have had the additional ground strap. There will be no indication on your regular harness as this strap is entirely independent.
You could always just wire it up without the ground and see if the left side works (if in doubt)?
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70plymA34] #1116191
11/21/11 03:27 PM
11/21/11 03:27 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The pics above came from a survivor '70 Cuda I owned that had an SPD of November 5th '69 and was built at the B-Hamtramck plant.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70plymA34] #1116192
11/21/11 03:39 PM
11/21/11 03:39 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Ditto, the cuda I just finished had no signs of this ground wire( hamtrack built car btw)
I will say. The one I did, did not have these style nuts holding the lamp in
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: gtx6970] #1116193
11/21/11 03:42 PM
11/21/11 03:42 PM
It's a dry heat
It's a dry heat
I had this style - April 1970 SBD
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: gtx6970] #1116194
11/21/11 05:01 PM
11/21/11 05:01 PM
Houston Texas
Houston Texas
My Cuda has the nuts as in the survivor pic and has an Oct. 10th build date. Not a survivor though... but my ground wire is exactly the same as in the pic with the same ends on it and everything.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: 70plymA34] #1116195
11/21/11 11:50 PM
11/21/11 11:50 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
The ground wire was not part of the harness. It was a single wire.
Re: 1970 CUDA Tail light wiring harness - couple questions. [Re: PAINT IT BLACK] #1116196
11/22/11 03:09 PM
11/22/11 03:09 PM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Everything works fine without the ground strap. thought all the lights were grounded to the the housings. when you pull a light socket out with lights on , the pulled light goes out.
