Re: 1970 CUDA Tail light wiring harness - couple questions.
[Re: aar1]
#1116181
11/18/11 09:58 PM
11/18/11 09:58 PM
Posts: 2,938 California
1970mopar
California
the trunk harness has a cloth type of wrapping, doesn't it? Not sure where you can get any of that. The wiring harness sold by Year One (made by M&H) is very good. Correct wiring, sockets and wrapping.
the original trunk wrapping is a cotton weave if I recall. I believe M & H can re-wrap your original harness if you call them directly.
The M&H repro harnesses are good reproductions, however the sockets are not 100% correct for OE. The side marker and two of the four tail lamp sockets differ from originals in appearance by quite a bit.
[Re: 70440+6bbl]
#1116187
11/19/11 03:22 PM
11/19/11 03:22 PM
Posts: 5,268 NY
70440+6bbl
NY
[Re: 70plymA34]
#1116191
11/21/11 03:27 PM
11/21/11 03:27 PM
Posts: 5,268 NY
70440+6bbl
NY
was this ground wire on all cudas??? i have an early build 1970 and i restored the original wiring harness and never saw any wires routed to grounding the harness. no cuts or anything. very interesting info......
The pics above came from a survivor '70 Cuda I owned that had an SPD of November 5th '69 and was built at the B-Hamtramck plant.
[Re: 70plymA34]
#1116192
11/21/11 03:39 PM
11/21/11 03:39 PM
Posts: 21,405 It's a dry heat
gtx6970
It's a dry heat
Ditto, the cuda I just finished had no signs of this ground wire( hamtrack built car btw)
I will say. The one I did, did not have these style nuts holding the lamp in
[Re: PAINT IT BLACK]
#1116196
11/22/11 03:09 PM
11/22/11 03:09 PM
Posts: 1,083 Long Island, NY
70plymA34
Long Island, NY
I am pretty certain your Cuda would have had the additional ground strap. There will be no indication on your regular harness as this strap is entirely independent.
You could always just wire it up without the ground and see if the left side works (if in doubt)?
Everything works fine without the ground strap. thought all the lights were grounded to the the housings. when you pull a light socket out with lights on , the pulled light goes out.
