Replacing Trans - use pilot bushing or roller bearing? #1115704
11/17/11 06:36 PM
11/17/11 06:36 PM
Retired now in Tennessee
Chi_Town_Runner Offline OP
Will be replacing my 4-speed trans in my '68 RR next month.
When we replaced the trans in my friends Formula "S" we used the newer roller bearing instead of the pilot bushing in the crank(his choice).
It looks like a nice piece. My bushing is relativley new but I was wondering, is the bushing preferred over the roller bearing or is the roller newer tech and better?
I know the roller is used on uncut cranks, but that is not an issue in my case.
Thanks for any input.
Frank
Remember - 2 wrongs don't make a right - but 3 rights make a left!
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: Chi_Town_Runner] #1115705
11/17/11 07:07 PM
11/17/11 07:07 PM
NE MISSOURI
P
Purpleracer Offline
Purpleracer  Offline
P
NE MISSOURI
I prefer the roller. Never did like the bushing type.
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: Purpleracer] #1115706
11/17/11 09:18 PM
11/17/11 09:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I hate the roller,just one more moving part to fail If you have just a small installation problem where the tranny doesn't go in just right you can damage the roller easily where the bushing is more forgiving when the pilot snout hits it wrong.
Gus
64 Plymouth Savoy
Dana 60
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: fourgearsavoy] #1115707
11/17/11 10:09 PM
11/17/11 10:09 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
rollers work fine I have pulled them out of cars that had 100k and them still look OK but have seen some that where tore up. but anything can fail I have also seen the bushing crack and fall into pieces.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: dusturbd340W5] #1115708
11/17/11 10:42 PM
11/17/11 10:42 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
aw heck,, put both of them in..
I am truckless..
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: 340SHORTY] #1115709
11/17/11 10:51 PM
11/17/11 10:51 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have one of each ahead of 833s in 2 fairly hot street cars, and can't tell any difference between the 2 in operation, if that's a consideration for you.
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: topside] #1115710
11/18/11 04:03 PM
11/18/11 04:03 PM
Northern Virginia
Moparmaniacc Offline
Northern Virginia
Sorry for jumping on your post, but if you have a crank that's not drilled for a 4-speed, and you use a roller, do you have to cut the mainshaft on the trans?
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: Moparmaniacc] #1115711
11/18/11 05:49 PM
11/18/11 05:49 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: Moparmaniacc] #1115712
11/18/11 06:15 PM
11/18/11 06:15 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I think the hole is sometimes deep enough but unfinished, sometimes not deep enough and the nose of the input shaft has to come off. I have an eagle crank in mine it had a deep enough hole but it was unfinished. I used the torque converter pocket style roller bearing. I was a little worried about smashing it on install but everything went smoothly.
good luck!
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: radar] #1115713
11/18/11 06:38 PM
11/18/11 06:38 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i have never found an intact roller bearing in a cummins clutch job--find only the shell---personally i not sold on them---but you probably wont get that kind of mileage out of your clutch---bob
Re: Replacing Trans - use pilot bushing or roller bearing? [Re: 340SHORTY] #1115714
11/18/11 08:24 PM
11/18/11 08:24 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
That's what I did. I had the bushing in and couldn't get it out, so I left it in and installed the roller bearing. It works just fine.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
