OK to use stock stamped rockers with this cam? #1115634
11/17/11 06:00 PM
11/17/11 06:00 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
http://store.440source.com/Comp-Cam-Xtreme-Energy-507_510/productinfo/145-1225/
I have a set of NOS stamped rocker arms, I was wondering if they were OK to use with this cam....
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115635
11/17/11 06:23 PM
11/17/11 06:23 PM
an8sec70cuda Offline
I don't see why not. Have a 440 here w/ the 509/292 MP purpleshaft cam and stock rockers. Been that way for 10 years or more w/ a lot of hard miles on it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: OK to use stock stamped rockers with this cam? [Re: an8sec70cuda] #1115636
11/17/11 06:24 PM
11/17/11 06:24 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
That sounds jut about right....this cam is very similar to the old MP 509
thanks!
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115637
11/17/11 06:25 PM
11/17/11 06:25 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
How do you think this cam would work on a 383 with stock ported heads and about 10:1 compression?
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115638
11/17/11 06:27 PM
11/17/11 06:27 PM
Kentucky
jbsperformance Offline
Kentucky
I'm using that exact cam with stock stamped rockers currently. Also used them on my 509 cam with no issues either.
Re: OK to use stock stamped rockers with this cam? [Re: jbsperformance] #1115639
11/17/11 06:28 PM
11/17/11 06:28 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
how do you like the cam? what engine do you have it in?
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115640
11/17/11 06:34 PM
11/17/11 06:34 PM
From my experience w/ 383's, I'd say not to use that much cam in it unless you have a lot of stall and a lot of gear. Even then, it's gonna be a dud down low w/ only 10:1 compression. It'll sound nasty, but that's about it.
CHIP
Re: OK to use stock stamped rockers with this cam? [Re: an8sec70cuda] #1115641
11/17/11 06:49 PM
11/17/11 06:49 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Then what would be a better cam choice for the 383?
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115642
11/18/11 10:39 AM
11/18/11 10:39 AM
Kentucky
Kentucky
So far I like it. Has more low end than the 509 (which is what I wanted) and has a nice lope. I've got a stock stroke 440 with 440 source heads and six pack. Engine is 60 over with 10.5 compression. I've got 4.10 gears and an old Turbo Action J converter (want to change both of those out later).
I agree that it may be too much for a 383 without a lot of gear and a big stall--no fun on the street.
Re: OK to use stock stamped rockers with this cam? [Re: domingo] #1115643
11/18/11 01:35 PM
11/18/11 01:35 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Check out the Hughes Whiplash cam. I run it in my 383. Has just as much out of the hole as the 262 CopmCam cam I was running, but from 3000 to 6000 RPM it rocks. Right now I'm running a 2500 stall converter. Will be changing to a 3500 stall soon. The heads on my engine are ported and blended 346, three angle 2.08/1.74 valve job. 3.73 gears. I'm running stock stamped steel rocker.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
