Re: 67 gtx grille pics
[Re: PROSATELLITE]
#1115318
11/18/11 12:34 AM
11/18/11 12:34 AM
Posts: 7,541 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
I have some decent close-ups of my Satellite which is the same as the GTX in front. The nice thing is there are only two paints; dark argent and black.
1. Black goes on the headlight doors' flat areas around the headlights and the thin verticals that hold the horizontals in the main grille area.
2. Dark Argent goes: - In the thin outside stripe that "surrounds" all of the grille elements. Headlight doors, hood trim, bottom of center grille. - On the three upper and lower thin horizontal stripes of the headlight doors. - On the three upper and lower thin horizontal "fins" across the center grille area. - In the inner recessed area of the headlight openings CLOSEST to the headlight lenses.
Hope this helps. PM me your email address and I can send you detailed pix. -Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
[Re: SNK-EYZ]
#1115320
11/18/11 11:29 AM
11/18/11 11:29 AM
Posts: 10,735 North Dakota
6PakBee
North Dakota
I know this is a bit off topic but there are two different styles of headlight doors and trim pieces for Belvedere's. One style has a white painted center and one has a black painted center. I own both styles, both 1967 Belvedere II's. The only differece I can see is one has the sill trim like a GTX and the other has the chrome trim strip at the top of the quarters/door/fender.
[Re: 6PakBee]
#1115322
11/18/11 11:06 PM
11/18/11 11:06 PM
67SATisfaction
Albany, NY
Got your PM's. Photos emailed. Quote:
Yeah, you never know with Ma Mopar. The '67 Plymouth sales catalog shows the convertible Belvedere II with Black in the recessed stripe surrounding each headlight door and on the hood edge trim. The Belv II hardtop is shown with White. The Belv I's are all White. Go figure.
[Re: 67SATisfaction]
#1115323
11/19/11 05:03 PM
11/19/11 05:03 PM
Posts: 5,044 At a gas station near you
badblack68
Art, I recieved the pictures. Thanks for the detailed explanation of the colors used and where they are applied. Your help is greatly appreciated. Mark
Nobody gets in to see the wizard! Ain`t no way! Ain`t no how!
