Re: Anyone using the Atomic EFI yet
[Re: ff6849]
#1115049
11/16/11 04:31 PM
11/16/11 04:31 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
Looks like it was just announced at SEMA. Not due out til Jan 2012 but I am sure there will be some magazine articles or reports by people that might be beta testing soon.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
[Re: finadk]
#1115053
11/16/11 08:29 PM
11/16/11 08:29 PM
finadk
East Brunswick, NJ
It looks like edelbtock also announced its e-street EFI similar to this and the Fast EZ EFI. I'm just hoping for the price wars to begin!!!! Scott
Scott
1976 Corvette
[Re: finadk]
#1115054
11/18/11 11:00 PM
11/18/11 11:00 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
I'l be buying it after the first of the year, talked to them at SEMA quite a bit. Will be installing 6AL, their Dist along with Atomic EFI. I want to run E-85 and be able to switch over to gas when E-85 isn't available. With this system you just plug in the hand held moniter and change it and timing over, this is the system I've been waiting for!!
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: Montclaire]
#1115057
02/27/12 07:57 PM
02/27/12 07:57 PM
Posts: 4,740 Florida
BDW
Price is only thing keeping me away, that would double the value of my car. Copied this from cuda-challenger, might not be all it's cracked up to be? Big selling point is no return line, but sounds like that's not really true. "i downloaded the instructions http://www.msdignition.com/WorkArea/DownloadAsset.aspx?id=15032386224 and its optional not to have a return line. there are a series of questions you need to fill out and put values in based on your answer. basically it tells you if you live in a hot climate its recommended to use a return system unless your running an in-tank fuel pump - which I'm not sure is possible...? if your in a more mild climate 70-80* and mount the pump within 2 feet of the tank, and are using octane 91 or higher your good to go. my climate is frequently 100+ so im wondering if its even worth it to bother with a returnless system at all - not something they tell you up front lol. drawback of living in the desert :/ SO with that in mind, at this point, do the initial install as a single line, and if i have problems later on....? find out why they dont want a hard line used, and if its trivial add the hardline into the system while converting to a return style, i would only have to do a simple re-route of a few hoses versus running a whole new hose."
[Re: DynoDave]
#1115059
02/27/12 08:52 PM
02/27/12 08:52 PM
Posts: 3,438 Dandridge TN
Dabee
Dandridge TN
I would love to have something like this.
The only thing that worries me about this design is the body mounted ecu. Having lived with Lean Burn, I hate to see modules right on top of the engine. I know...it's 40 year newer technology, but still....
I'm also not a fan of having the ecu, TPS, MAP, IAT and fuel pressure sensors all baked into one block. Cleaner install? Sure, But if any one of those 5 components fails, you are replacing all 5. $$$$$ Wouldn't mind seeing commonly available sensors and parts being used...much easier access to parts in the future.
Dave, those are all good points. I’m waiting to see how it works out before pulling the trigger. I’m still leaning toward the FAST with port injection. It’s more money and more work to install but I think it will perform better.
