Re: 70 Dart A14 Spring Special Question
[Re: sixpaktoogo]
#1114074
11/15/11 01:45 AM
11/15/11 01:45 AM
Posts: 4,442 Texas
Daty Rogers
World's Greatest Husband. I love you Robyn
Texas
Gaylen don't give a f@ck about A-Bodies, not suprised. I don't have any info either, sorry. -Daty
[Re: sixpaktoogo]
#1114078
11/17/11 08:27 PM
11/17/11 08:27 PM
Posts: 243 St. Louis, MO
DodgeMaterial
St. Louis, MO
From an April built 1970 Dart Swinger 6-cyl Monroney Label:
A14 - Dart Swinger Sales Package - $293.25 Includes: 6.94x14 WSW Polyester Tires Deluxe Wheel Covers Deluxe Vinyl Bench Seat Steering Wheel - Rim Blow (2 spoke) LH Remote Mirror Carpets Vinyl Body Side Mouldings Bumper Guards F&R Belt Mouldings Wheel Lip Mouldings
and... which I believe was the value of this package the next item on the sticker...
D34 Torqueflite Transmission was No Charge. I am not near a scanner - but hopefully this helps you.
DodgeMaterial - Dave
JS29U0B - FK5 - 440-4 Auto
WS23V0A - EB5 - 440-6 Auto
[Re: DodgeMaterial]
#1114080
11/17/11 09:31 PM
11/17/11 09:31 PM
DodgeMaterial
St. Louis, MO
Here is a copy of that Monroney. Dave
[Re: sixpaktoogo]
#1114082
11/18/11 05:28 AM
11/18/11 05:28 AM
Posts: 27,467 So Cal
autoxcuda
So Cal
Dave,
Thanks so much for the information. The only difference I see on my car is the tires. Mine came with D78-14 dual white stripe tires. Coded on the broadcast sheet as T16. My car was assembled at the Windsor plant as well (same as yours). What's interesting, is that the A14 code is not on the fender tag, but is only on the broadcast sheet.
Dan
Is your car a /6 also?
[Re: autoxcuda]
#1114083
11/18/11 10:18 AM
11/18/11 10:18 AM
Posts: 636 California
sixpaktoogo
California
Dave,
Dan
Yes, but I have a friend who has a 70 Dart with A14 on his broadcast sheet, with a 318. His was also assembled at Windsor as well. Don't know why the window sticker shown says "final assembly Detroit, Michigan", when the plant code is "R" (Windsor).
[Re: sixpaktoogo]
#1114084
11/18/11 10:47 AM
11/18/11 10:47 AM
DodgeMaterial
St. Louis, MO
I am pretty sure you could upgrade the tires to the larger size and if your car has A/C (with automatic trans) the larger tires might have been required. From our research on the Valiant project we found in 1970 that the 6.95x14 tires were single stripe wsw and the larger D78x14 were dual stripe wsw. Since this is a marketing package it is not surprising the A14 code is not on the fender tag. Dave
[Re: DodgeMaterial]
#1114085
11/18/11 12:21 PM
11/18/11 12:21 PM
sixpaktoogo
California
Hi Dave,
Yes my car does have A/C, so that might be why the larger tires. I know it does have the 318 torsion bars because of the a/c.
Dan
