70 Dart A14 Spring Special Question #1114073
11/15/11 01:32 AM
11/15/11 01:32 AM
California
sixpaktoogo Offline OP
California
Does anyone know what is included in the Spring Special, code A14, for a 1970 Dart? Galen's book says "no information available".
Thanks, Dan
Re: 70 Dart A14 Spring Special Question [Re: sixpaktoogo] #1114074
11/15/11 01:45 AM
11/15/11 01:45 AM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
Gaylen don't give a f@ck about A-Bodies, not suprised. I don't have any info either, sorry.
-Daty
Re: 70 Dart A14 Spring Special Question [Re: Daty Rogers] #1114075
11/16/11 02:39 PM
11/16/11 02:39 PM
California
California
Nobody? Dan,where are you?
Re: 70 Dart A14 Spring Special Question [Re: sixpaktoogo] #1114076
11/16/11 03:54 PM
11/16/11 03:54 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Re: 70 Dart A14 Spring Special Question [Re: kentj340] #1114077
11/16/11 07:37 PM
11/16/11 07:37 PM
Farmington, CT
KISSAlien Offline
KISSAlien  Offline
Farmington, CT
Did you check:
http://www.hamtramck-historical.com/library.shtml
for 1970?
And this:
http://www.oldcarbrochures.com/static/NA/Dodge/1970_Dodge/dirindex.html
for 1970?
You definitely won't find info like this in a normal brochure. You'd have to find that info in a special flyer specific to that model that was meant for the dealership only. Typically these spring special packages were just a way to order a group of options under one code at a cheaper price. They usually are no big deal.
To see an example you can look at the What's New from Dodge links on the Hamtramck-Historical page linked to above.
Re: 70 Dart A14 Spring Special Question [Re: sixpaktoogo] #1114078
11/17/11 08:27 PM
11/17/11 08:27 PM
St. Louis, MO
DodgeMaterial Offline
St. Louis, MO
From an April built 1970 Dart Swinger 6-cyl Monroney Label:
A14 - Dart Swinger Sales Package - $293.25
Includes:
6.94x14 WSW Polyester Tires
Deluxe Wheel Covers
Deluxe Vinyl Bench Seat
Steering Wheel - Rim Blow (2 spoke)
LH Remote Mirror
Carpets
Vinyl Body Side Mouldings
Bumper Guards F&R
Belt Mouldings
Wheel Lip Mouldings
and... which I believe was the value of this package the next item on the sticker...
D34 Torqueflite Transmission was No Charge. I am not near a scanner - but hopefully this helps you.
DodgeMaterial - Dave JS29U0B - FK5 - 440-4 Auto WS23V0A - EB5 - 440-6 Auto
Re: 70 Dart A14 Spring Special Question [Re: DodgeMaterial] #1114079
11/17/11 09:09 PM
11/17/11 09:09 PM
GMP440 Offline
GMP440  Offline
I had a girlfriend years ago that had a 71' Dart with those same options. Don't know if it was that code on the fender tag. At that time no one was looking at codes. This was in 86'. Her car was dark brown.
Re: 70 Dart A14 Spring Special Question [Re: DodgeMaterial] #1114080
11/17/11 09:31 PM
11/17/11 09:31 PM
St. Louis, MO
St. Louis, MO
Here is a copy of that Monroney. Dave
Re: 70 Dart A14 Spring Special Question [Re: DodgeMaterial] #1114081
11/18/11 05:12 AM
11/18/11 05:12 AM
California
California
Dave,
Thanks so much for the information. The only difference I see on my car is the tires. Mine came with D78-14 dual white stripe tires. Coded on the broadcast sheet as T16. My car was assembled at the Windsor plant as well (same as yours). What's interesting, is that the A14 code is not on the fender tag, but is only on the broadcast sheet.
Dan
Re: 70 Dart A14 Spring Special Question [Re: sixpaktoogo] #1114082
11/18/11 05:28 AM
11/18/11 05:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Dave,
Dan
Is your car a /6 also?
Re: 70 Dart A14 Spring Special Question [Re: autoxcuda] #1114083
11/18/11 10:18 AM
11/18/11 10:18 AM
California
California
Dave,
Dan
Yes, but I have a friend who has a 70 Dart with A14 on his broadcast sheet, with a 318. His was also assembled at Windsor as well. Don't know why the window sticker shown says "final assembly Detroit, Michigan", when the plant code is "R" (Windsor).
Re: 70 Dart A14 Spring Special Question [Re: sixpaktoogo] #1114084
11/18/11 10:47 AM
11/18/11 10:47 AM
St. Louis, MO
St. Louis, MO
I am pretty sure you could upgrade the tires to the larger size and if your car has A/C (with automatic trans) the larger tires might have been required. From our research on the Valiant project we found in 1970 that the 6.95x14 tires were single stripe wsw and the larger D78x14 were dual stripe wsw. Since this is a marketing package it is not surprising the A14 code is not on the fender tag. Dave
Re: 70 Dart A14 Spring Special Question [Re: DodgeMaterial] #1114085
11/18/11 12:21 PM
11/18/11 12:21 PM
California
California
Hi Dave,
Yes my car does have A/C, so that might be why the larger tires. I know it does have the 318 torsion bars because of the a/c.
Dan
