Manifold prep and paint for non judged cars #1114064
11/15/11 01:10 AM
11/15/11 01:10 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
What is the best process to clean up a used set of manifolds and then what products are recommended to apply after clean up? Not going on a judged vehicle, just want them to look good.
-C
Re: Manifold prep and paint for non judged cars [Re: ramman5600] #1114065
11/15/11 10:31 AM
11/15/11 10:31 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Ive had good results from just sandblasting and brushing on Eastwoods High Temp Stainless Coating. Its a lighter gray than the cast iron gray most people use.
Be sure to wear gloves when handling the parts once theyre blasted.
Re: Manifold prep and paint for non judged cars [Re: LimeliteAero] #1114066
11/15/11 06:55 PM
11/15/11 06:55 PM
Horsham, Pa.
Finoke Offline
Finoke  Offline
Horsham, Pa.
I agree, and at any time you can touch up the manifolds with the same eastwood product after the car is on the road.
Re: Manifold prep and paint for non judged cars [Re: LimeliteAero] #1114067
11/15/11 11:31 PM
11/15/11 11:31 PM
Michigan, USA
Michigan, USA
This product?
http://www.eastwood.com/stainless-steel-high-temp-coating-kit.html
Re: Manifold prep and paint for non judged cars [Re: ramman5600] #1114068
11/16/11 09:53 AM
11/16/11 09:53 AM
MD
floyd Offline
floyd  Offline
MD
I used the darker stuff:
http://www.eastwood.com/factory-gray-high-temp-coating-kit.html
Depends on your preference. Either way, you will likely get good results with either paint as long as your prep work is good.
Re: Manifold prep and paint for non judged cars [Re: ramman5600] #1114069
11/16/11 10:26 AM
11/16/11 10:26 AM
SE Pa.
SE Pa.
This product?
Thats what I used on several sets of manifolds.
Re: Manifold prep and paint for non judged cars [Re: LimeliteAero] #1114070
11/16/11 01:41 PM
11/16/11 01:41 PM
MoreParts Offline
MoreParts  Offline
I really have only had luck with about 1/2 of Eastwood's products. Happily, this stuff was in the WINNING half. I applied it to a set as described above about 15 years ago and it still looks great!
Re: Manifold prep and paint for non judged cars [Re: MoreParts] #1114071
11/18/11 05:17 PM
11/18/11 05:17 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I have been using cast colored powder coat, looks great and lasts a long time..........
Admiration For Multiple Carburetor Vehicles...
