64 Plymouth Savoy/Bel. with Hemi #1113719
11/14/11 05:48 PM
11/14/11 05:48 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
What needs to be done to the passager side inner finderwell to put a 426 Hemi in it? Thinking about building one for NSS?
Thanks for any help & links Brian
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: Bishop] #1113720
11/14/11 06:08 PM
11/14/11 06:08 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Here is a Inverted shock tower with the correct scallop out of the inner fender... Stock valve covers.
here is with no valve covers... Engine has factory offset and location. BTW
good pic of modified inner fender area.
That mod make even the tall Keith Black aluminum covers clear. I was able to remove these in the car using bolts in the valve covers. Not studs.
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: Bishop] #1113721
11/14/11 06:32 PM
11/14/11 06:32 PM
at large
moparphillie Offline
at large
In my 1965 Plymouth Belvedere I, I used Schumacher engine mounts with the Stock V/8 K Member and TTI 2 1/8" Headers and I did not have to modify the Passenger side shock tower nor did I have to notch the Passenger side fenderwell for valve cover clearance.
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: moparphillie] #1113722
11/15/11 10:29 AM
11/15/11 10:29 AM
Mountains of NM
65superstock Offline
Mountains of NM
Moparphillie: To be sure I understand you, are you able to take off the valve covers without a problem?
I ask because I want to use the same mounts/k-member/headers in my 65 Coronet and I was dreading having to cut the shock tower up since it is finished as far as paint is concerned.
-Jason
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: 65superstock] #1113723
11/15/11 04:46 PM
11/15/11 04:46 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We have done this conversion many times without modifying the shock tower.The only thing we remove is the passenger side shock at the top to remove the valve cover.
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: 65superstock] #1113724
11/15/11 08:46 PM
11/15/11 08:46 PM
at large
at large
Hey Brian,
Please see Bob George's response. I can remove the Passenger side valve cover without any major problem. It is easier to accomplish by removing the Passenger Side upper shock retaining nut, which is no big deal. I live in Centerville, OH, just up I-75. If you want to come by and check it out, just let me know.
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: moparphillie] #1113725
11/15/11 09:10 PM
11/15/11 09:10 PM
Mountains of NM
Mountains of NM
Excellent! Thanks for the replies, guys.
-Jason
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: 65superstock] #1113726
11/16/11 02:00 AM
11/16/11 02:00 AM
Ohio
jdfpam Offline
jdfpam  Offline
Ohio
Brian,
If you don't already have a car, let me know, my father is going to sell his. It is a 1964 Plymouth Savoy with a 426 Hemi. It is already set up to run NSS and IHRA AA/SA.
Jeff Day
Precision Automotive Machine
Canton, Ohio
(330)456-3045
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: Bishop] #1113727
11/16/11 02:18 AM
11/16/11 02:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I have room in my '63
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 64 Plymouth Savoy/Bel. with Hemi [Re: Bishop] #1113728
11/16/11 10:34 AM
11/16/11 10:34 AM
Missouri, Cole county
gbolten480 Offline
gbolten480  Offline
With the cast aluminum covers - I had to raise the motor - due in part from not inverting the shock tower. I'll try to attach a picture. I raised the motor buy placing a quarter inch thick spacer between the solid motor mounts which bolt to the block, & the rubber mounts. Prior to raising the motor - the cover sat on the tower, - was odd, seemed as if everything hit home at once.
