Hesitation at lower RPMs #1113588
11/14/11 03:59 PM
11/14/11 03:59 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
At WOT from 2600 +/- RPMs there is no stumble or hesitation, but anything before that at WOT it will stumble for a second before taking off. Do you think the stumble is fuel related at lower RPMs? Timing?
Re: Hesitation at lower RPMs [Re: wtucker] #1113589
11/14/11 04:08 PM
11/14/11 04:08 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Sounds like maybe the accelerator pump might not be working or giving too small a shot. This happens just when you floor it? Take off the air cleaner and give the throttle a blip and you should see a good squirt of gas.
I have mechanical Aptitude.
I can screw up anything.
Re: Hesitation at lower RPMs [Re: bboogieart] #1113590
11/14/11 04:13 PM
11/14/11 04:13 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
I replace the original 30 with a 50cc, which helped. Could initial fuel pressure be to low? At idle its about 5.5, not sure what it goes to an WOT
Re: Hesitation at lower RPMs [Re: wtucker] #1113591
11/14/11 04:19 PM
11/14/11 04:19 PM
What eng/carb/recent mods/always done it/cold and hot? So at part throttle it will hesitate for a sec then take off OK accelerating OK moderately at part throttle? CHeck float level/acell pump squirt tip in/duration. Ideally would be to tape a vac gauge to the windshield/run it to manifold vac & take it out & note the highest in hg it hesitates at after confirming the float/squirt is good. May need richer pri jets or "cruise" step (eddy) or a higher # PV and a vac leak would do it but for now assuming it is a lean tuning prob
Re: Hesitation at lower RPMs [Re: wtucker] #1113592
11/14/11 04:58 PM
11/14/11 04:58 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
need a bigger pump shot or some more timing.
Coming soon!!!!
Re: Hesitation at lower RPMs [Re: Mr.Yuck] #1113593
11/15/11 03:59 PM
11/15/11 03:59 PM
Virginia Beach, Va
wtucker Offline OP
wtucker  Offline OP
Virginia Beach, Va
Eng 440 .30 over, street dominator, 850 Mighty Demon, 452 ported and milled .10, 238/244 huges Hyd cam, 2500 converter, 4.10 gears. It's been doing it for a while. I've changed to a bigger squirter 31 (I think), increased the primary jets 2 sizes. I tried changing to heavier and lighter springs in the dizzy. I'll try and give it more initial timing (currently about 12) and see what happens.
Re: Hesitation at lower RPMs [Re: wtucker] #1113594
11/15/11 04:45 PM
11/15/11 04:45 PM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Adjust the acc pump. I had the same issue w/a 670 Holley at low rpm until I got in the throttle. It needed just a squirt to eliminate the hesitation.
Re: Hesitation at lower RPMs [Re: wtucker] #1113595
11/15/11 08:12 PM
11/15/11 08:12 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
If it has a slight stumble or hesitation under light or part throttle acceleration at lower rpm, there could be something amiss in the idle/transition circuit of the carb as well.
Re: Hesitation at lower RPMs [Re: BSB67] #1113596
11/15/11 09:11 PM
11/15/11 09:11 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Had the same problem and went through the carb numerous times with jets accelerator pump shot adjustments with no change. Bumped the timing up to 18 initial and all in by 2200 and all the hesitation was gone.
Re: Hesitation at lower RPMs [Re: Todd] #1113597
11/15/11 11:23 PM
11/15/11 11:23 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I agree, more int. timing & most likely a faster curve, Vacuum is too low at 5.5 with a cam that size, low int. timing will do that.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Hesitation at lower RPMs [Re: joedust451] #1113598
11/15/11 11:29 PM
11/15/11 11:29 PM
Midwest
MoparsnMissiles Offline
Midwest
Same here, bump the timing up a few degrees. World of difference.
