Re: Hesitation at lower RPMs
[Re: wtucker]
#1113589
11/14/11 04:08 PM
11/14/11 04:08 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Sounds like maybe the accelerator pump might not be working or giving too small a shot. This happens just when you floor it? Take off the air cleaner and give the throttle a blip and you should see a good squirt of gas.
I have mechanical Aptitude. I can screw up anything.
[Re: wtucker]
#1113591
11/14/11 04:19 PM
11/14/11 04:19 PM
RapidRobert
What eng/carb/recent mods/always done it/cold and hot? So at part throttle it will hesitate for a sec then take off OK accelerating OK moderately at part throttle? CHeck float level/acell pump squirt tip in/duration. Ideally would be to tape a vac gauge to the windshield/run it to manifold vac & take it out & note the highest in hg it hesitates at after confirming the float/squirt is good. May need richer pri jets or "cruise" step (eddy) or a higher # PV and a vac leak would do it but for now assuming it is a lean tuning prob
[Re: Todd]
#1113597
11/15/11 11:23 PM
11/15/11 11:23 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
Had the same problem and went through the carb numerous times with jets accelerator pump shot adjustments with no change. Bumped the timing up to 18 initial and all in by 2200 and all the hesitation was gone.
I agree, more int. timing & most likely a faster curve, Vacuum is too low at 5.5 with a cam that size, low int. timing will do that.
[Re: joedust451]
#1113598
11/15/11 11:29 PM
11/15/11 11:29 PM
Posts: 116 Midwest
MoparsnMissiles
Midwest
Same here, bump the timing up a few degrees. World of difference.
