Bo29 Hemmi #1113295
11/14/11 01:26 AM
11/14/11 01:26 AM
seattle wa
BOBBYBOY Offline OP
BOBBYBOY  Offline OP
seattle wa
I am the new owner of the Bo29 HEMMI cuda that was on ebay 2 months ago , the Defrank-Cohen , originally Gentle Ben car .The car is blowing blue smoke out of the left bank only .I made sure the plugs were clean from any oil from the spark plug tubes but it keeps getting oil on the left bank plugs & blows blue smoke after 1 min from starting , what are your thoughts on this , there is only 10 hrs on the engine according to the guy I bought the car from .
Re: Bo29 Hemmi [Re: BOBBYBOY] #1113296
11/14/11 01:33 AM
11/14/11 01:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
10 hours a quarter mile at a time can be A LOT of miles! You can't trust most sellers these days and even the honest ones sell cars with unknown mechanical woes. Race hemis are not Toyota 4 bangers, they USUALLY require frequent maintainance and a knowledgable mechanic to deal with it. You likely have a wounded warrior on your hands and that will likely go really south REALLY fast without finding the issue, not something a first time Mopar owner will have a good time with. I'd reccomend getting someone in the know to help you out. If you post the cars location we can likely send you in the right direction. If it's in Seattle you might contact www.rocketresto.com and ask for Mike, he knows his stuff
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113297
11/14/11 01:35 AM
11/14/11 01:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113298
11/14/11 01:51 AM
11/14/11 01:51 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also try Peter Willie, he owns and races a 68 S/S Hemi Barracuda (clone) and does all of his own engine building, he's VERY good with race hemis and not far from you.
Peter Willie/Victoria Transmission
Victoria, BC Canada
(250)382-2833
Pwille50@shaw.ca
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113299
11/14/11 01:52 AM
11/14/11 01:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Engine has a few more mods than yours likely does
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113300
11/14/11 01:52 AM
11/14/11 01:52 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Barely qualifies as a crossram
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113301
11/14/11 01:53 AM
11/14/11 01:53 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Scott, don't ya think a PM of the Ph # / address might be better?
Re: Bo29 Hemmi [Re: BOBBYBOY] #1113302
11/14/11 01:55 AM
11/14/11 01:55 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
brace yourself for
Re: Bo29 Hemmi [Re: 1_WILD_RT] #1113303
11/14/11 01:56 AM
11/14/11 01:56 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Normally but in this case it's ok, that's Pete's business info, he's ok with it
Re: Bo29 Hemmi [Re: ScottSmith_Harms] #1113304
11/14/11 01:57 AM
11/14/11 01:57 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Cool.. I figured you were on it but though I'd ask...
Re: Bo29 Hemmi [Re: 1_WILD_RT] #1113305
11/14/11 10:46 AM
11/14/11 10:46 AM
Sebring, Florida
Mopar Grandpa Offline
Sebring, Florida
Have you done a leak down on the cylinders? Could have some bad or broken rings. What about valve guides and seals? You could also call Charlie Wescott and get his opinion.
BTW, I've never heard of a racer talk about an engine in hours, always in number of passes.
Re: Bo29 Hemmi [Re: Mopar Grandpa] #1113306
11/14/11 11:33 AM
11/14/11 11:33 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i guess that depends on how slow the car is.....
Re: Bo29 Hemmi [Re: BOBBYBOY] #1113307
11/14/11 03:52 PM
11/14/11 03:52 PM
ohio
silverhemiboy Offline
ohio
I am not an expert but my hemi was doing something like yours and i was thinking valve guides or rings. As it turns out we had a leaking intake manifold. We fixed it and the oil out the exhaust stopped immediately. Of course we did a leak down test before hand and then just started with the easiest thing to check next. Just food for thought. Best of luck.
Re: Bo29 Hemmi [Re: silverhemiboy] #1113308
11/14/11 04:09 PM
11/14/11 04:09 PM
MId West
wasacuda Offline
wasacuda  Offline
MId West
I would make sure the intake manifold is sealed. If the block has been decked and the intake was not cut to fit it will pull oil into the cylinders. I have has a few real Hemi Darts and Cuda's over the years and one had the same problem. I had the intake cut and the problem went away. Good luck.
Re: Bo29 Hemmi [Re: BOBBYBOY] #1113309
11/14/11 10:52 PM
11/14/11 10:52 PM
It is not uncommon for 426 hemiroids to suck oil into the cylinders from intake gasket leaks Do you own a leakdown meter and know how to do a leak down test? If so post the results. BTW,Andy DeFrank and Jim Cohen had a few different SS/AA 1968 Baracudas and Darts over the years Andy Defrank had more once they split up, I remember several different DeFrank SS/AA cars with that paint scheme at Pomona over the years, Rick Hauser drove a lot of them for Mr Defrank
Re: Bo29 Hemmi [Re: Cab_Burge] #1113310
11/14/11 11:57 PM
11/14/11 11:57 PM
seattle wa
BOBBYBOY Offline OP
BOBBYBOY  Offline OP
seattle wa
Thanks for the help , guys I am leaning towards the intake manifold , especialy after talking to some hemmi guys at the sat car show at Indian Bend road in Scottsdale Az[they have a show every sat , up to 500 cars especialy during the auctions ]I am currently at my winter home in Cave Creek Az , I will check this out next week. What do you guys think of the bo29 car currently on ebay , there is no buck tag or core support number , I bid on it in sept at Barrett
Jackson Las vegas but quit at $60,000 because of questionable documentation , wrong seats , dash etc .
Re: Bo29 Hemmi [Re: BOBBYBOY] #1113311
11/15/11 12:25 PM
11/15/11 12:25 PM
Staten Island, NY
RO23dave Offline
RO23dave  Offline
Staten Island, NY
Cave Creek, great little town, spent a few hours there as my brother lives about 20 mins away. my thought would be to check the intake gaskets first. if there's oil down the intake runner you've most likely found your problem. have you checked the plugs on that side to see if you can narrow it down to 1 particular cylinder? dave #1355 ss/ea
Re: Bo29 Hemmi [Re: RO23dave] #1113312
11/15/11 01:55 PM
11/15/11 01:55 PM
dogdays Offline
dogdays  Offline
Well, the chances of having all the rings or valve guide seals on one bank go bad while the others don't, are much smaller than having an intake manifold leak. So this isn't an original thought but that's what it is. New gaskets should fix you right up. Congratulations on your purchase!
R.
Re: Bo29 Hemmi [Re: dogdays] #1113313
11/15/11 11:45 PM
11/15/11 11:45 PM
West Coast, CA
Troy Offline
Troy  Offline
West Coast, CA
Would love to see some pictures of the car and engine......
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
