New best with the 408 in the Duster #1112291
11/12/11 10:22 PM
11/12/11 10:22 PM
PA.
pittsburghracer Online work OP
"Little"John
pittsburghracer  Online Work OP
"Little"John
PA.
Whiskyrunner and I went to the last race of the season at Pittsburgh Raceway Park and ran a couple of new bests with the 408. Matt wanted to try his hand at box racing today so he was today's driver. He broke into the 9's with a 9.98@130.25mph the eight mile time was 6.26@107.42mph. 60' time was a 1.34
He lost in the second round today as the wind made dialing a little tricky. Over all I am happy with the performance with this combo. I think the power glide transmission is hurting some but its very consistent. We are running 93 octane gas mixed with one gallon of 110. ( 4-1 ratio) I plan on building another stroker as a backup for next year going with higher compression and a bigger cam.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112292
11/12/11 10:47 PM
11/12/11 10:47 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Right on! She's gum bootin' along pretty good!
-Kenny
Re: New best with the 408 in the Duster [Re: StrokerAspen] #1112293
11/13/11 12:13 AM
11/13/11 12:13 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Good numbers!
Post could be enhanced by specs on the combo and PICS ! ! !
Please and thank you.
Re: New best with the 408 in the Duster [Re: cudadoug] #1112294
11/13/11 01:14 AM
11/13/11 01:14 AM
PA.
"Little"John
"Little"John
PA.
Good numbers!
1970 duster 2600#
powerglide (stock 2.76 low gear)
4:88 dana
.030 over 360 block 10.5-1 diamond pistons
4" stroke K1 crank, K1 rods
set of W2 heads I ported (2.020 intake valves)flow 292@.550 lift
550 lift Racer Brown cam MP rockers
750 Holley, W2 Victor intake
shifting at 6400rpm
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112295
11/13/11 09:32 AM
11/13/11 09:32 AM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
congrats I was wondering are you running factory front suspension and steering components? I am thinking of upgrading mine I was curious because of how light you got the car
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112296
11/13/11 10:45 AM
11/13/11 10:45 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Very nice John.....
RIP Monte Smith
Re: New best with the 408 in the Duster [Re: CompWedgeEngines] #1112297
11/13/11 12:29 PM
11/13/11 12:29 PM
PA.
"Little"John
"Little"John
PA.
Very nice John.....
Thanks Todd. I did a lot of upgrades to the car this year while waiting to get the Daytona in the body shop. Matt wanted the 360 that we ran last year for his car so I built a new 408 for this year. Some of the upgrades were changing the car to a powerglide, fitting the adapter plate, new tranny mount, shifter, drive shaft, new set of double adjustable ladder bars, rewired the car and added a racepak and dash, new fuel pump and lines from cell to carb. The new engine sounded and felt great on the warm up road but on its first pass my BG regulator stuck open and sent 22# of fuel pressure through the engine. I thought for sure it washed the rings as it sounded and ran like crap for a couple of test sessions. With the info from the racepak we finally turned things around.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: BLONDE BARRACUDA] #1112298
11/13/11 12:42 PM
11/13/11 12:42 PM
PA.
"Little"John
"Little"John
PA.
Its a box tube frame car with a front mounted rack and pinion. The car has a factory type strut setup and disk brakes but I don't know what type of car they came from. I will probably unload the car today and I will try to post some pictures of the setup. I love how the previous owner mounted the front end. It has stock metal fenders and by removing 4 bolts behind the front tires it lifts right off. 2 guys 2 minutes or less. I would recommend using an after market strut and brakes as it would be lighter and easier to get parts if you need them.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112299
11/13/11 06:20 PM
11/13/11 06:20 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Congrats
Despite the weight, it does run good for a fairly mild motor. These small blocks never cease to amaze me.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112300
11/13/11 06:22 PM
11/13/11 06:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Damn that thing`s flyin................... What`s that thing weigh?
Re: New best with the 408 in the Duster [Re: Thumperdart] #1112301
11/13/11 08:54 PM
11/13/11 08:54 PM
PA.
"Little"John
"Little"John
PA.
Right around 2600#
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112302
11/13/11 08:59 PM
11/13/11 08:59 PM
, PA
sleepyhead416 Offline
, PA
I bet he was 1 Happy Dude. WTG
Re: New best with the 408 in the Duster [Re: sleepyhead416] #1112303
11/13/11 09:05 PM
11/13/11 09:05 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
Way to John & Matt!!!!
I wish I could have been there, but it was my turn to work on Saturday!!
If you ever need to slow it down, let me drive it!!!
"I've upped my horsepower, so...... UP YOURS!!!"
Re: New best with the 408 in the Duster [Re: sleepyhead416] #1112304
11/13/11 09:40 PM
11/13/11 09:40 PM
PA.
"Little"John
"Little"John
PA.
I think I was more excited then he was Harold. He did say to me " I wouldn't touch a thing for next year" But you know me. I will probably paint it over the Winter and with edelbrock coming out with new heads there will be another bullet on the engine stand. Here are some pictures from yesterday. Also congrats go out to Nick Bowman for his runner up yesterday. That kids a machine.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112305
11/14/11 10:13 AM
11/14/11 10:13 AM
tboomer Offline
tboomer  Offline
Pretty good,John!! And nice pics!
Re: New best with the 408 in the Duster [Re: pittsburghracer] #1112306
11/14/11 06:09 PM
11/14/11 06:09 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Nice
Re: New best with the 408 in the Duster [Re: HardcoreB] #1112307
11/14/11 07:43 PM
11/14/11 07:43 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Very Cool John. Nice to see you got out one last time before the snow settles in. Beep
