Where to find 11x2.5 Rear Brakes #1111678
11/11/11 11:40 PM
11/11/11 11:40 PM
Illinois
saukvillage Offline OP
Illinois
I need brakes for my dana rearend. What model/year of car, truck, van, etc that came with the larger 11x2.5 brakes and hopefully, I may be able to find in the junk yard for parts need it such as the backing plates. All information shall be appreciated, Thanks
Re: Where to find 11x2.5 Rear Brakes [Re: saukvillage] #1111679
11/11/11 11:52 PM
11/11/11 11:52 PM
scratchnfotraction Offline
I run a set of 11x2.5 brakes off a 73 newport 8 3/4,i have a set of new shoes on the shelf.
most of the truck 9 1/4s have the 11x2.5 drums and backing plates should swap over.
Re: Where to find 11x2.5 Rear Brakes [Re: scratchnfotraction] #1111680
11/12/11 12:07 AM
11/12/11 12:07 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Some 8 3/8 rears from trucks have em too. My Club Cab does.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Where to find 11x2.5 Rear Brakes [Re: MoPar Jamie] #1111681
11/12/11 12:50 AM
11/12/11 12:50 AM
Jamie those are unGodly heavy but have considered them. Did you notice better braking going from std 10" to them?
Re: Where to find 11x2.5 Rear Brakes [Re: RapidRobert] #1111682
11/12/11 11:55 AM
11/12/11 11:55 AM
when i went from 10x2 to 11x2.5 on my 68dart with the 73 disc front I noticed a big diff in brakeing power and distance.
never locked them up and it would stop short and give change.
heavy,yes,but the stoping distance alone was worth the extra weight IMHO
try a 440 with 9' drums on all 4 corners,go to next town turn around drive slowly back to stop sign
Re: Where to find 11x2.5 Rear Brakes [Re: scratchnfotraction] #1111683
11/12/11 12:01 PM
11/12/11 12:01 PM
Thank you Michael, Sounds worth it
Re: Where to find 11x2.5 Rear Brakes [Re: RapidRobert] #1111684
11/12/11 11:15 PM
11/12/11 11:15 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
PM me. I have a set I'm never going to use.
I even took 9" drums off my Slant car because it was spooky to try and stop at the track.
Re: Where to find 11x2.5 Rear Brakes [Re: slantzilla] #1111685
11/12/11 11:22 PM
11/12/11 11:22 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I think I have some 11"x3" drums out in the shed.
Dulcich said to use smaller wheel cylinders on my A body to keep from having lock up problems.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Where to find 11x2.5 Rear Brakes [Re: Rug_Trucker] #1111686
11/12/11 11:28 PM
11/12/11 11:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Cop[ spec Diplomats have them too. I upgraded my 87 Diplomat from 10.87" disc/10" drums to 11.75 disc/11" drums, big different in stopping distances.
Don't be the exception.
Re: Where to find 11x2.5 Rear Brakes [Re: saukvillage] #1111687
11/13/11 02:47 AM
11/13/11 02:47 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Advance Auto Parts has the drums and shoes.
Nautilus Racing-
Re: Where to find 11x2.5 Rear Brakes [Re: Chris2581] #1111688
11/13/11 07:12 PM
11/13/11 07:12 PM
NH
Fastback67 Offline
Fastback67  Offline
NH
Drums and shoes are easy, the backing plates on the other hand...
Year One sells them if you want to pay big $$$$. Unless you happen to be headed to a big swap meet next week, the salvage yard is going to be your best alternative.
Re: Where to find 11x2.5 Rear Brakes [Re: Fastback67] #1111689
11/13/11 07:45 PM
11/13/11 07:45 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I have several sets. C-bodies and trucks usually had them.
I have them on my 72 SSP 440 with disc up front. Real happy with them.
I've never seen a 11x3 on the rear, just on the front.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Where to find 11x2.5 Rear Brakes [Re: moparmarks] #1111690
11/13/11 08:46 PM
11/13/11 08:46 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
you can even pull them off the older 9.25---some even have the extra 5th hole used on the 8.75---bob
Re: Where to find 11x2.5 Rear Brakes [Re: savoy64] #1111691
11/13/11 10:10 PM
11/13/11 10:10 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
These are 11 X 3 inch backing plates, so if Rug Trucker has drums
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Where to find 11x2.5 Rear Brakes [Re: hemi71x] #1111692
11/13/11 10:43 PM
11/13/11 10:43 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I think I have a couple complete pairs of 11 x 3" rear brakes.
One has 5 x 4 1/2" bolt pattern, the other has 5 x 5". Because 5" pattern 3" rear drums were standard on '60s Imperials, the large pattern drums are much more common than the 5 x 4 1/2" version.
Re: Where to find 11x2.5 Rear Brakes [Re: DoctorDiff] #1111693
11/13/11 11:11 PM
11/13/11 11:11 PM
hemi71x Offline
hemi71x  Offline
Ya, that's what my 3 incher's, came off of.
A 69 Imperial.
Re: Where to find 11x2.5 Rear Brakes [Re: hemi71x] #1111694
11/13/11 11:52 PM
11/13/11 11:52 PM
moparmarks Offline
moparmarks  Offline
A 69 Imperial.
Guess thats why I've never seen them. I've never parted out an Imperial.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Where to find 11x2.5 Rear Brakes [Re: moparmarks] #1111695
11/14/11 12:17 AM
11/14/11 12:17 AM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I have several sets as well. Looks like you need not spend big money at year one, or go to junk yards.
There are three people right here that have offered.
Slantzilla from Ill. near you
moparmark from Colo. a little farther
bboogieart from Wisc. in between the two, distance wise
looks like you came to the right place. just send a couple pm's and get yer best deal.
I have mechanical Aptitude.
I can screw up anything.
Re: Where to find 11x2.5 Rear Brakes [Re: bboogieart] #1111696
11/14/11 08:52 PM
11/14/11 08:52 PM
Park Forest, IL
Park Forest, IL
If he is indeed in Sauk Village he can almost throw a rock and hit my house.
