Lets Talk About Door Hinges #1111454
11/11/11 06:49 PM
11/11/11 06:49 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I haven't looked into the subject much lately and there a lot of possibilities on the market now.
I need to get my 71 Dusters door hunges in top shape before the body work gets started, which option makes the most sense these days and looks the most original when done? Reproduction hinges? Rebuilt hinges? Something else?
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111455
11/11/11 10:34 PM
11/11/11 10:34 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
My vote is for re-built hinges. There are two very reputable and able bodied gentlemen in the great state of Wisconsin that can help. Resto-Rick and Rich Berlisk (formerly of Almost NOS)
Admiration For Multiple Carburetor Vehicles...
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111456
11/11/11 11:27 PM
11/11/11 11:27 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
in order of prefereance to me
NOS or mint used
New reproduction
rebuilt originals
my main problem with rebuilt hinges is they have a bushing in them that can be seen after they are done
Re: Lets Talk About Door Hinges [Re: gtx6970] #1111457
11/11/11 11:47 PM
11/11/11 11:47 PM
Great White North
Furyman Offline
Furyman  Offline
Great White North
The Amd hinges are nice.They come bushed.
"Long Live Mopars"
Re: Lets Talk About Door Hinges [Re: Furyman] #1111458
11/12/11 12:44 AM
11/12/11 12:44 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
The only problem with the AMD hinges is that the S spring is not notched like the original one. It will take time,openeing and closing the door, for it to make a groove on the S spring. I just replaced my lower hinge and found that out.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Lets Talk About Door Hinges [Re: 70sixpkrt] #1111459
11/12/11 12:53 AM
11/12/11 12:53 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'd buy NOS hinges if I could find them (hint hint wanted ad)
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111460
11/12/11 01:36 AM
11/12/11 01:36 AM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
It seems to me that, if you want the original appearance, someone could weld the hinge pin holes closed a bit, then re-machine to the proper size hole. Grind off the excess weld on the surface. Voila. New factory hinges?
Re: Lets Talk About Door Hinges [Re: lahatte] #1111461
11/12/11 02:27 AM
11/12/11 02:27 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I did exactly that with my Roadrunner. Time consuming,but the results are great. I did use new pins from the Help section, since the pins were worn as well. The new welded areas are unlikely to wear, since weld is harder than CRS.
Re: Lets Talk About Door Hinges [Re: sthemi] #1111462
11/12/11 11:24 AM
11/12/11 11:24 AM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Superbird Bob in the Seattle area does hinges. Great guy and he does nice work.
Re: Lets Talk About Door Hinges [Re: MO_PA] #1111463
11/12/11 11:30 AM
11/12/11 11:30 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
Re: Lets Talk About Door Hinges [Re: gygeneral] #1111464
11/12/11 09:24 PM
11/12/11 09:24 PM
California
BigDaddy440 Offline
BigDaddy440  Offline
California
Did you check with SMS.
http://www.smsmopar.com/Door-Hinges.html
I just had Rod at SMS take care of my hinges as well as a few other items. I haven't bolted them back up (and won't for a long while) but the overall experience I had with SMS was positive.
-dan
1969 A12 Roadrunner
1970 Plymouth Cuda
1968 Dodge Dart
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111465
11/12/11 09:53 PM
11/12/11 09:53 PM
O
OLD318 Offline
OLD318  Offline
O
Well, this is one of those areas where you have several options.
If you have the money and are of the mind
"Everything MUST be brand spanking new"
go spend it and buy new ones or ante up for NOS.
However, My personal opinion is (unless they are rusty/rusted out):
rebuild your originals.
Let's face it, this hobby is pricey enough replacing stuff that
HAS to be replaced...
It gets REALLY pricey when you start replacing that which
"Really doesn't need to be replaced"...
Obviously, If you want to replace them, me telling you otherwise
won't change your mind....
But IMHO:
Brand new pins, bushings, and the S spring on the lower hinge
are fairly cheap and the rebuild is easy to do.
Usually, you only really need to rebuild the driver side.
On 2 door cars, the passenger side is not really worn that bad.
it's just...old...
If you rebuild them yourself
There are 2 schools of thought
Disassemble, blast(clean), repaint, then reassemble
or
disassemble, blast(clean), re-assemble, then repaint..
The only difference is the appearance on the car.
If you want originality go with the latter...
Bottom line: This is a pretty easy DIY job:
Save your replacement money for other stuff that really needs replacing.
Best of luck to you and thanks for all your contributions to the hobby and this site!
Re: Lets Talk About Door Hinges [Re: gtx6970] #1111466
11/15/11 02:39 AM
11/15/11 02:39 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
You can rebuild your hinges without the extra bushing that was not there originally. RestoRick sells an oversize pin with reamer.
I like this option.
If you want to know how to remove the S spring and put it back, see photo. Clamp the S spring in a vise as shown, and twist the top of it with a crescent wrench. Slide the stamping downward to clear the S spring groove. Just be sure to take your own photos so you get it back together right.
Re: Lets Talk About Door Hinges [Re: kentj340] #1111467
11/15/11 01:56 PM
11/15/11 01:56 PM
Salinas, California
1970Cuda Offline
super street
1970Cuda  Offline
super street
Salinas, California
Aren't there date codes on the hinges? Wouldn't you want to put the correct date coded units back onto your car?
Re: Lets Talk About Door Hinges [Re: 1970Cuda] #1111468
11/15/11 05:36 PM
11/15/11 05:36 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
I went with Resto-Rick and have nothing but great things to say. He'll send you everything you need and doing it yourself is far from rocket science. Save your money for something that matters.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: Lets Talk About Door Hinges [Re: klunick] #1111469
11/15/11 06:02 PM
11/15/11 06:02 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Hey Scott,
If you would decide on rebuilt ones, there is a fella very very close to you that does a perfect pro job at lil guy prices.
res1vw21@gmail.com His name is Ross.
He also would mind explaining how he does them and what parts he uses if you wanted to do it yourself, but time vs labor in your world it might be easy to buy a set nos or rebuilt.
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111470
11/19/11 02:12 AM
11/19/11 02:12 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
How stock do they have to look? I make full length pin sleeves that will fit inside the inner hinge and weld them in. That way it spreads the load of the pin the full length instead of just 3/16" on the ends. A grease zerk can be put midway. No more sagging doors....
Re: Lets Talk About Door Hinges [Re: 52savoy] #1111471
11/19/11 02:22 AM
11/19/11 02:22 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I'm looking for 100% original appearance when done.
Re: Lets Talk About Door Hinges [Re: ScottSmith_Harms] #1111472
11/20/11 04:36 PM
11/20/11 04:36 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
If you leave the grease fitting off you would have to look pretty close to notice the inner part of the hinge has a slighty larger diameter where the pin should be. I have them on one of my Hemi cars and even after 23 years not one show car judge has caught it.. I make my sleeves out of stainless.
But I know you do pretty rare customer cars and that's a lot different than doing your own car.
If you don't mind a little more extra work, you can always drill out the damaged holes and tig weld a short(1/4") stainless bushing in...
or go the easy way out and buy the repair kit sold at many parts stores.
