Page 1 of 3 1 2 3
So...what do you all have planned for over the winter. #1111191
11/11/11 03:25 AM
11/11/11 03:25 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Hey all
I was just curious what everyone's plan for their cars over the winter. I myself am kind of at a crossroads. I think the coronet has a lot more in it with a few tweaks to the chassis. So, I'll be focusing on that for me.
What are you all doing?
Mike
1969 Dodge Dart Swinger
Re: So...what do you all have planned for over the winter. [Re: MikeyT] #1111192
11/11/11 04:38 AM
11/11/11 04:38 AM
Mo.
racerx Offline
racerx  Offline
Mo.
My plans r to install some sort of A/F meter so i can tune in this e-85 carb.
Re: So...what do you all have planned for over the winter. [Re: racerx] #1111193
11/11/11 04:58 AM
11/11/11 04:58 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Nothing till after the first of the year,,,then not sure after that, kind of interested in the new smallblock Eddy heads.
Re: So...what do you all have planned for over the winter. [Re: MikeyT] #1111194
11/11/11 09:17 AM
11/11/11 09:17 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
Complete front suspension rebuild with offset uca bushings, new headers and redesign the exhaust.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: So...what do you all have planned for over the winter. [Re: bigsbigelow] #1111195
11/11/11 09:28 AM
11/11/11 09:28 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
Too much Can see it lasting till Mar/April'12
Move House (3 weeks time)
Remove Motor & Box
Strip front end, repaint & put back together
Rebuild motor
get box freshened
Motor & box back in
Then finalise turbo install, new Fuel system,MAP FI
Some where in-between that lot, do some bits on the house
Re: So...what do you all have planned for over the winter. [Re: mopar_mark] #1111196
11/11/11 09:42 AM
11/11/11 09:42 AM
dayton,ohio
ROSSIO Offline
ROSSIO  Offline
dayton,ohio
putting the frt end on a major "weight loss" program and then freshen up the motor.
thats plenty enough for right now
1970 DART B1MC N/A 8.86@ [Email]155 3200 lb on 275 DR 5.30 @ 130 1/8
Re: So...what do you all have planned for over the winter. [Re: ROSSIO] #1111197
11/11/11 09:54 AM
11/11/11 09:54 AM
Bergen County NJ
N
NoJoke Offline
NoJoke  Offline
N
Bergen County NJ
I plan on having my 65 Belvedere 1 complete for next season....
Re: So...what do you all have planned for over the winter. [Re: NoJoke] #1111198
11/11/11 10:17 AM
11/11/11 10:17 AM
Canada
Kam*Kuda Offline
Kam*Kuda  Offline
Canada
TONS
Rebuild the engine for the procharger
Finish the procharger setup
Have a tranny build to withstand the new power
New Driveshaft Loop etc
Switch to a Locker for the Dana
Forgot, sending my heads to Dwayne Porter to get done
May pull out all the wiring for the fast xfi system so that I can dyno the engine
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: So...what do you all have planned for over the winter. [Re: Kam*Kuda] #1111199
11/11/11 10:25 AM
11/11/11 10:25 AM
Out West
408strokerdart Offline
Out West
Loose a few more pounds, tweak my combo a little more, CNC port the heads.....then go get my 8 second N/A small block time slip. Probably going to run the divisionals next year in Super Street and try my hand at that throttle stop/pro tree racing stuff.
Re: So...what do you all have planned for over the winter. [Re: 408strokerdart] #1111200
11/11/11 10:36 AM
11/11/11 10:36 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
In order until I run out of cash...
Replace all front end bushings.
Engine rebuild.
Change shifter handle.
Engine compartment detail.
Add power brake booster.
Replace brake drums and shoes.
Re: So...what do you all have planned for over the winter. [Re: mopar_mark] #1111201
11/11/11 12:01 PM
11/11/11 12:01 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
finally got the 63 Dodge back in the garage after all these years in the trailer...so I'm planning on finishing it and installing the 499 that was in the Duster..
and..
pull the engine from the Camaro and freshin it up along with some upgrades..
it will be a busy and expensive winter to say the least...but I'll have fun
Re: So...what do you all have planned for over the winter. [Re: MikeyT] #1111202
11/11/11 12:03 PM
11/11/11 12:03 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Pretty much the same thing I'd planned for LAST winter... which goes to show how (un)sucessful that effort was.
Re: So...what do you all have planned for over the winter. [Re: BradH] #1111203
11/11/11 12:05 PM
11/11/11 12:05 PM
tboomer Offline
tboomer  Offline
Brad... I happen to know of a test mule for those Victor heads as long as you are not using them...
Re: So...what do you all have planned for over the winter. [Re: tboomer] #1111204
11/11/11 12:18 PM
11/11/11 12:18 PM
BradH Offline
BradH  Offline
Re: So...what do you all have planned for over the winter. [Re: MikeyT] #1111205
11/11/11 12:26 PM
11/11/11 12:26 PM
Long Island, New York
W
W7 Duster Offline
W7 Duster  Offline
W
Go through everything. New tires, maybe change gears, maybe Q16. Putting together a list now.
Re: So...what do you all have planned for over the winter. [Re: W7 Duster] #1111206
11/11/11 01:02 PM
11/11/11 01:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Just plan to upgrade to a larger electric fuel pump over the red Holley pump on it now. Other then that just plan to tweak the car over the next few years hoping to work it down to 10.50's. Ron
Re: So...what do you all have planned for over the winter. [Re: 383man] #1111207
11/11/11 01:09 PM
11/11/11 01:09 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Line lock, braided brake lines, 2" headers, run braided 3/8 line to carbs........ummm that should do it. Hope to pick up a tenth or 2.
Coming soon!!!!
Re: So...what do you all have planned for over the winter. [Re: dartman366] #1111208
11/11/11 01:15 PM
11/11/11 01:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well as of Wednesday it sounds like I could be having a very big sale over the winter.
Re: So...what do you all have planned for over the winter. [Re: MikeyT] #1111209
11/11/11 01:30 PM
11/11/11 01:30 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Carbed/Forged Eddy headed 408
Bigs Stage5 950HP
CSR water pump
Manual brake conversion
Manual steering conversion ?
Complete rewire (again)
6 point Roll Bar
Kirky seat & 5 point harness
Weight loss...Me and the truck.
I would have started by now, but I'm 3rd in points in the Mopar Shootout, last race tomorrow.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: So...what do you all have planned for over the winter. [Re: Adobedude] #1111210
11/11/11 01:40 PM
11/11/11 01:40 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
My plans are simple. Move the car in the back of the garage, place it on jack stands, and put the cover on it. Then bring out the snowmobiles.
Page 1 of 3 1 2 3
