What can I expect for E.T. #1111136
11/11/11 12:43 AM
11/11/11 12:43 AM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
HI I have a '72 Scamp with a '69 340. Stock rods stock 10.5 pistons Stock steel crank. Ported J heads,2.08 in 1.60 ex., solid purple shaft 571 lift 304 duration cam, LD340 intake, 750 eddy carb., 727 with Huges 4000 stall, MSD ignition, Dana 60 4.10's, with 29" tall tire. Full interior car. Just want a ball park idea what you guys think. If you need more info to determine, let me know. Thanks!
Re: What can I expect for E.T. [Re: 340Scamp] #1111137
11/11/11 01:02 AM
11/11/11 01:02 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I will take a stab. Mid to low 12's. Good luck , Ron
Re: What can I expect for E.T. [Re: 340Scamp] #1111138
11/11/11 01:22 AM
11/11/11 01:22 AM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
CAR WEIGHT - TYPE OF TIRE - TUNE UP - AIR =11.50 15.50
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: What can I expect for E.T. [Re: 340Scamp] #1111139
11/11/11 01:40 AM
11/11/11 01:40 AM
Renton Washington
Triple Threat Offline
Renton Washington
I'm not a fan of that Carb, and the tire is a bit tall. The rest looks good.
If you're lucky it will tickle the 11's, most likely a 12 second car though as it sits.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What can I expect for E.T. [Re: Triple Threat] #1111140
11/11/11 02:17 AM
11/11/11 02:17 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Hey Dustin, you bringing the scamp to Mason Dixon saturday? - Andy
Re: What can I expect for E.T. [Re: 340_Dart] #1111141
11/11/11 02:27 AM
11/11/11 02:27 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Too much gear for 340cid. Id say mid 12s.
Re: What can I expect for E.T. [Re: viperblue72] #1111142
11/11/11 03:18 AM
11/11/11 03:18 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Really depends on how it hooks. I'd guess 12.32 @114 mph
Mike
1969 Dodge Dart Swinger
Re: What can I expect for E.T. [Re: 340Scamp] #1111143
11/11/11 11:44 AM
11/11/11 11:44 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
12.80-13.0 w/ that carb. 12.40-12.50 w/ a holley. Good luck. Open exhaust or closed?
Coming soon!!!!
Re: What can I expect for E.T. [Re: 340Scamp] #1111144
11/11/11 11:54 AM
11/11/11 11:54 AM
Get-X Offline
Get-X  Offline
Assuming the suspension works and it's in a good state of tune it should run mid to high 11's.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: What can I expect for E.T. [Re: Get-X] #1111145
11/11/11 12:07 PM
11/11/11 12:07 PM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Once you get things dialed in, I would say 11's.
BTW that cam is ground with zero advance, advancing it 3-4 degrees may benenfit your ET.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: What can I expect for E.T. [Re: viperblue72] #1111146
11/11/11 02:19 PM
11/11/11 02:19 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
If you meant "Not enough gear for 340".
Re: What can I expect for E.T. [Re: 340Scamp] #1111147
11/11/11 02:56 PM
11/11/11 02:56 PM
Throwing in actual hands on expereieces I will say mid to high 13s. Sory for not stroking your ego, BTW what brand and style tires are you going to use at the track? I'm basing my guess on some good hooking street and strip tires When are you going to run the car and which track? Eddy makes several versions of the 750, a smog carb and a performance version , which one do you have?
Re: What can I expect for E.T. [Re: Cab_Burge] #1111148
11/11/11 03:02 PM
11/11/11 03:02 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Thats kinda what I was thinking..
Re: What can I expect for E.T. [Re: RemCharger] #1111149
11/11/11 04:52 PM
11/11/11 04:52 PM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
I ran a similar combo in my Dart years ago. Car weighed 3470 with driver, had sportsman pro tires and 430 gear. Car would run 12.90- 13.00 depending on the weather.
Re: What can I expect for E.T. [Re: gtsdon] #1111150
11/11/11 05:58 PM
11/11/11 05:58 PM
P
Paul_Fancsali Offline
P
I will venture with that carb a et of 13.2-13.5 that carb and tall ass tires are going to take the wind out of your sails. Get the tire to 26 tops and or more gear 4.10s are great but you will have them around a 3.55 overall with 29 tall tires. Get a Holley dbl pumper, shorter slick and look for 12.0-12.3
Re: What can I expect for E.T. [Re: Paul_Fancsali] #1111151
11/11/11 09:36 PM
11/11/11 09:36 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
You guys are low ballin it, If that car & the combo (assumeing) the alt. isn't exstream & your not a heavy weight doesn't see 11s i'd junk it , I was told MANY MANY times that my 71 Dart with a junkyard 360 magnum, bolt-ons, very small re-ground cam, 3.73 gears, 11" 2800 stall & a 650dp would never see a 12.99 period, 1st. pass letting off just past the 1000ft. it ran 12.70, After that run it was a solid 12.5 car & 105 with 1.80 60fts. shifting at 5100, this was at 24-2600 DA, race weight was un-known. 3 things that need to be changed IMO, then like mentioned, advance the cam.
Run at least a prepped 750dp., Even an 850dp will work good.
Install 4.56 gears & a 28" tire, With that cam & a 340 don't be surprized if you need to shift at or a bit over 7K RPM.
I would go with a 46-4800 Flash stall.
For now to keep cost down, i'd run 27" Slicks or QTPs.
I'll say once you get thinks in order & weight & Alt. are on the lower side.
high 11s
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: What can I expect for E.T. [Re: 340Scamp] #1111152
11/11/11 10:51 PM
11/11/11 10:51 PM
Wisconsin
BLONDE BARRACUDA Offline
Wisconsin
11.8
Re: What can I expect for E.T. [Re: BLONDE BARRACUDA] #1111153
11/11/11 11:33 PM
11/11/11 11:33 PM
Western Colorado
3
340Scamp Offline OP
340Scamp  Offline OP
Western Colorado
Thanks everyone. I forgot to mention this is a street car. I think anything steeper than 4.10's will be to much for the street. It's a 750 Performance carb. Thanks again.
Re: What can I expect for E.T. [Re: 340Scamp] #1111154
11/12/11 01:22 AM
11/12/11 01:22 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
12.20's after tuning w /those gears and carb. I guess my 4.86 are way too much
Yeah, it's got a smallblock.
Re: What can I expect for E.T. [Re: 340Scamp] #1111155
11/12/11 01:39 AM
11/12/11 01:39 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
I ran all over in my 73 Swinger, had a built up .060" 360 & 4.56 gears, 255/60/15s, they are 27" tall, It cruised really nice & was torquey as hell, I dropped in a set of 3.23s i had for kicks, god what a pig it turned into, so the 4.56s went back, Even if its a Performer 750 its still an eddy, You will benifit more from a holley DPer. Unless you plan on doing alot of highway cruising, drop in a steeper gear, 4.56s are nothing for a street cruiser.
