Anyone remote power steering pump on an older Mopar #1111072
11/10/11 10:44 PM
11/10/11 10:44 PM
Washington State
70chall440 Offline OP
Washington State
I am trying to figure out how to run a remote PS pump/reservoir on my 73 Cuda (416 CI, EFI 6 pac) and wondering if anyone out there is or has done it. There appears to be several options running from the Type II GM style to the late model Mopar versions. However I do not know the line pressure I should be looking for and subsequently would will work. I want to run one to clean up the left side of the motor and since this is a bit of a road race car, I think it will give me some options; not to mention I am not fond of the factory PS pumps, expecially thier pulleys. I can fabricate the brackets once I have a pumpt to work with.
01 Viper GTS ACR
10 Challenger RT PCP 6spd
70 Challenger 440 6 pac
73 Cuda 416 Road Racer
70 Hemi Roadrunner
01 Ram 4x4 / 98 Ram 3500
91 Stealth RT
05 Durango Hemi
09 Caliber / 99 Dakota 4x4 / 52 Dodge B3B
Re: Anyone remote power steering pump on an older Mopar [Re: 70chall440] #1111073
11/11/11 01:30 AM
11/11/11 01:30 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Re: pressure. IIRC, a recent MA article said that
Mopar pumps for B/E bodies were originally 1300 psi or so. However, they were overboosted. A zero-buck fix was to add a washer in the valve assembly that dropped it to 700-850 or so for just-as-good steering with much better road feel to the wheel.
Can't talk to pump replacement, though.
Lots of late model vehicles have the remote reservoirs. Even my 86 Supra had a remote reservoir...
Re: Anyone remote power steering pump on an older Mopar [Re: MoparMarq] #1111074
11/11/11 07:03 PM
11/11/11 07:03 PM
Washington State
Washington State
thanks, I remember reading about that now that you mention it. You are right, there are lots of pumps. I just needed a place to start (now I have one).
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Anyone remote power steering pump on an older Mopar [Re: 70chall440] #1111075
11/11/11 08:35 PM
11/11/11 08:35 PM
AndyF Offline
AndyF  Offline
The late model pumps from a GM can be made to work if you have some machining capability. These pumps are nice and light and easy to find replacement parts for.
Re: Anyone remote power steering pump on an older Mopar [Re: AndyF] #1111076
11/11/11 09:54 PM
11/11/11 09:54 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
That's pretty slick Andy.
Re: Anyone remote power steering pump on an older Mopar [Re: POS Dakota] #1111077
11/11/11 11:10 PM
11/11/11 11:10 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
You can get a remote saginaw pump from a mid-late 80's chebby diesel with hydroboost, they have a remote resevoir. Tim
Re: Anyone remote power steering pump on an older Mopar [Re: AndyF] #1111078
11/12/11 12:10 AM
11/12/11 12:10 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Hey Andy what pulley is that on the pump in your pic?
Re: Anyone remote power steering pump on an older Mopar [Re: RV2] #1111079
11/12/11 12:13 AM
11/12/11 12:13 AM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Some of the mid-late 80s HD trucks with the 360-4v also had a remote resevoir. They had two smog pumps so they had to have the remote resevoir. The pump bolts to a stock bracket IIRC and you would have to find a place to mount the resevoir.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Anyone remote power steering pump on an older Mopar [Re: MoPar Jamie] #1111080
11/12/11 06:57 PM
11/12/11 06:57 PM
Washington State
Washington State
that is excellent information. I talked to Firm Feel, and they told me that the stock Mopar (70's era) steering box was designed to accept 800 psi (the pressure of a stock Mopar PSP), however the new pumps used on Challengers, Chargers etc are 1000 psi. they said they have seen them (the new pumps) used on vintage Mopar's without issue, however they feel 1000 psi is a bit much.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
Re: Anyone remote power steering pump on an older Mopar [Re: 70chall440] #1111081
11/12/11 08:19 PM
11/12/11 08:19 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
The stock mopar pumps like the one pictured above is a POS, we run them on jeeps and go through them like crazy. Get a good saginaw with brackets and never worry about them again. Tim
Re: Anyone remote power steering pump on an older Mopar [Re: astjp2] #1111082
11/13/11 01:26 AM
11/13/11 01:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I thought this was a Sagninaw pump pictured below and in AndyF's post? That pump is the same style as the ones we run on our circle track cars.
Re: Anyone remote power steering pump on an older Mopar [Re: autoxcuda] #1111083
11/13/11 04:08 AM
11/13/11 04:08 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
That is the same pump as a jeep cherokee with a 4.0, the 94 wrangler pump is remote resevoir and the same style. I like the older pumps, they seem to last longer, like one you would find in a 70-90's GM or Dodge truck. It helps to have a cooler too. If you want that style of pump, check out Vanco's site and PSC
http://www.pscmotorsports.com/
http://www.vancopbs.com/
Re: Anyone remote power steering pump on an older Mopar [Re: astjp2] #1111084
11/13/11 04:13 AM
11/13/11 04:13 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
This is more like what I would buy, need a pulley though and stock brackes from small block fit. TIm
http://www.pscmotorsports.com/94-02-dodg...e-feed-can.html
Re: Anyone remote power steering pump on an older Mopar [Re: astjp2] #1111085
11/13/11 04:51 AM
11/13/11 04:51 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That looks like the oval canned Saginaw pumps use off and on in late 60's all the way up to the 80's.
The Federal and Eaton round filler neck pump, IMHO, blow.
Re: Anyone remote power steering pump on an older Mopar [Re: autoxcuda] #1111086
11/13/11 05:07 AM
11/13/11 05:07 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These are the modern remote pumps most race car use nowdays:
Here's the same type/idea with a modified bracket to work on the Hotchkis E-Max Challenger 340 motor.
Re: Anyone remote power steering pump on an older Mopar [Re: autoxcuda] #1111087
11/13/11 10:55 AM
11/13/11 10:55 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
What AN attachments are you using
1. to get the high pressure side from the pump to the sector
2. the fittings on the sector for the high pressure and low pressure sides side
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: Anyone remote power steering pump on an older Mopar [Re: kilroy] #1111088
11/13/11 12:04 PM
11/13/11 12:04 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Never mind.
Found some here. Does this look right?
http://www.jimsautoparts.com/steering_parts.htm
FW-923 Power Steering High Pressure Hose FITTINGS Fits All Year, Make & Model $ 39.95/pr
Re: Anyone remote power steering pump on an older Mopar [Re: 70chall440] #1111089
11/13/11 02:18 PM
11/13/11 02:18 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Did this in my '67 and have now have one in my '74. Thinking of adding hard lines from the tank to in front of the radiator support and plumbing in a cooler next summer.
Re: Anyone remote power steering pump on an older Mopar [Re: kilroy] #1111090
11/13/11 03:17 PM
11/13/11 03:17 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Never mind.
No. That's just a right angle version of what you probably allread have on your car. It's just compression fitting, not AN.
You need a fitting that goes from that thread in the box with a o-ring to AN. I thought there was something out there. Check/call http://www.ormebrothers.com/
DO NOT buy anything from Jims Auto Parts. They have a horrible reputation in this industry for service and price. For example that Saginaw power steering pump rebuild kit Jims lists for $89 can be bought at Rock Auto or any local parts store for under $20.
Re: Anyone remote power steering pump on an older Mopar [Re: autoxcuda] #1111091
11/13/11 08:25 PM
11/13/11 08:25 PM
Washington State
Washington State
I agree, especially dealing with the pullys. finding the right brackets can also be a pain. These are some of the reasons I am going with a remote reservoir style. Another thing I want to do is a use a regulator inline with the pump and a pressure gauge, I am "thinking" I might be able to "dial in" the streering feel via pressure regulation. Now I just have to find the pump to use.
01 Viper GTS ACR
70 Hemi Roadrunner
91 Stealth RT
05 Durango Hemi
