Tire and wheel question #1110727
11/10/11 10:39 AM
11/10/11 10:39 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I have a 1969 Coronet R T with the build sheet.
Under Tires is T83
wheel is 16 Q5
wh cover is 89
What do these codes mean,I know Q5 is the color?
Thanks for all answers
Re: Tire and wheel question [Re: 5carguy] #1110728
11/10/11 10:52 AM
11/10/11 10:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Can only find the tire , it's an F70x14 Red stripe sidewall. Showing the wheel is body color , assume the car is Q5, then it's a 14x5.5 steelie, code is not in my old white book and new ones are at home. If this is correct then the wheel cover is the red circle dog dish , full cover wheels weren't painted body color .
Re: Tire and wheel question [Re: JohnRR] #1110729
11/10/11 11:09 AM
11/10/11 11:09 AM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
John,
What brand of tire,Firestone, Goodyear ?
Re: Tire and wheel question [Re: 5carguy] #1110730
11/10/11 01:22 PM
11/10/11 01:22 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Good question , but I think Goodyear , which isn't made repop me thinks? ?
Re: Tire and wheel question [Re: 5carguy] #1110731
11/10/11 02:32 PM
11/10/11 02:32 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Tires is T83
** T83 is the STANDARD high performance 383/440 b-body tire for '69 - F70X14 "red streak" NYLON cord construction. Most probably a Goodyear "SPEEDWAY" (this tire is available reproduction from Kelsey Tire). Depending on assembly plant and/or production date: some '69 b-bodies recieved Firestone F70X14 "WIDE OVAL DELUXE CHAMPION" tires (I have yet to see a '69 383/440 Coronet "WM/WS" or Belvedere "RM/RS" with Firestones).
wheel is 16 Q5
** 16 is the STANDARD high performance 383/440 b-body wheel for '69 - 14X5.5"
** Q5 - it is painted body color - "bright turquoise metallic".
wh cover is 89
** 89 is the STANDARD "dog dish" hub cap, part # 2944089 - stainless/red stripe/fratzog
Re: Tire and wheel question [Re: 6bblgt] #1110732
11/11/11 01:05 AM
11/11/11 01:05 AM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
Goodyear switched from Speedway Wide Treads to Polyglas red stripes approximately April of '69.
Contact me if you have any questions about Goodyears.
Thanks to 6bbl for having the code info!
Snarl softly and carry a BIG stick 1969 Hurst/Olds Pure Stock 13.23@ 103.1 and the a/c blows cold! Rusty Small
Re: Tire and wheel question [Re: SmallHurst] #1110733
11/11/11 04:28 AM
11/11/11 04:28 AM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
Not quite ..... The Polyglas was available (OPTIONAL) all year 383/440 (it was STANDARD on HEMI cars - F70X15 in size).
The STANDARD performance F70X14 "red stripe" across the board was a nylon cord tire (Super Bee, Road Runner, Charger R/T, GTX, Coronet R/T) for most cars this was the Goodyear "SPEEDWAY" sales code was T83. (This is the tire that lasted less than 20K miles & people about.)
OPTIONAL at NO-CHARGE was a performance F70X14 "white stripe" this was also a nylon cord tire (Super Bee, Road Runner, Charger R/T, GTX, Coronet R/T) for most cars this was the Goodyear "SPEEDWAY" sales code was T82. (This is another tire that lasted less than 20K miles & people about.)
OPTIONAL at $26.45 was a performance F70X14 "red stripe" this was the new to MOPAR fiberglass belted tire (Super Bee, Road Runner, Charger R/T, GTX, Coronet R/T) for ALL cars this was the Goodyear "POLYGLAS" sales code was T85. (Huge improvement in ride, grip, longevity. )
Firestone WIDE OVAL DELUXE CHAMPION nylon cord "red stripe" T83 & "white stripe" T82 tires have been found to be original on Hamtramck, MI assembled '69 Chargers. Charger is the only b-body assembled at Hamtramck in 1969.
* Reproduction "SPEEDWAY" tires are built fiberglass-belted just like the "POLYGLAS" tires ..... so no !!
Re: Tire and wheel question [Re: 6bblgt] #1110734
11/11/11 11:39 AM
11/11/11 11:39 AM
Lees Summit, MO
SmallHurst Offline
SmallHurst  Offline
Lees Summit, MO
I was going with information that Kelsey gave me. In '69, the Camero switched from the Speedway to Polyglas in April of '69.
In '68, Polyglas showed up on the '68 Hurst/Olds and the 68 1/2 Cobra Jet Mustang.
The F70-14Polyglas red stripe is available as well as the Speedway.
