Page 3 of 3 1 2 3
Re: weird cylinder heads on 440... spark plug won't fit?!?? [Re: dem440c] #1110717
11/16/11 03:03 AM
11/16/11 03:03 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I have a set of those 452 heads with the tapered seat plugs. They also have the little dimple below the plugs. Mine were bought as bare castings over the counter about 1992/1993. They were then sent to a machine shop and had bronze valve guide "sleeves" installed and Mopar Performance valves (2.14" & 1.88"), comp cams valve springs, locks & retainers, and had "some" port work done. Nice thing about them was the smaller plugs helped the plug wire clear the 2" Hooker headers with out burning the wire ends. Not to mention none of the bolt holes were worn out, stripped out or rusted out.
The bad thing, I was in Indy in 1995 at the Mopar Nationals, and on the last time run sat, blew the center out of a Champion spark plug. No problem, we're surrounded by mopar people, right? Yeah right. Everyone I ask looked at me like I had two heads. Finally went to K-mart and found a set of Bosch Platinums for about $20. (remeber, this was 1995!) Never went racing with out a spare set of plugs again. Those heads pick my car up by .2/sec over stock 906's.
Brian Dunnigan
Re: weird cylinder heads on 440... spark plug won't fit?!?? [Re: dem440c] #1110718
11/16/11 11:42 AM
11/16/11 11:42 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
440-3 engines always seem to have the tapered seat plug and could be either a 213 head or a 452 head depending on year.
Re: weird cylinder heads on 440... spark plug won't fit?!?? [Re: joedust451] #1110719
11/16/11 04:05 PM
11/16/11 04:05 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
If someone has a junk 452 head with the peanut plugs & that boss, may want to take a bit & grind it down just to msee if there is a jacket under it.
Why not just use the right plug and leave it at that?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: weird cylinder heads on 440... spark plug won't fit?!?? [Re: DPelletier] #1110720
11/16/11 05:15 PM
11/16/11 05:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would only make sense ...
Re: weird cylinder heads on 440... spark plug won't fit?!?? [Re: JohnRR] #1110721
11/16/11 09:15 PM
11/16/11 09:15 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
And alot of the times the big 3 didn't make sense
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Page 3 of 3 1 2 3
