Re: e3 spark plugs
[Re: oldtimer5151]
#1110477
11/09/11 08:11 PM
11/09/11 08:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I looked in the old posts and could not find anything on the e3 spark plugs. Does any one use them?
Why use them... with a cut back ground strap its proven that they make more power... WHY have 3 ground straps blocking the flame front
Re: e3 spark plugs
[Re: oldtimer5151]
#1110480
11/09/11 08:44 PM
11/09/11 08:44 PM
MR_P_BODY
I`ve read their claim and also read an article in circle track magazine. It seamed to recommend them for stock engines but not one word for race engines. I agree with you. The flame kernel ignites the fuel and the still travels the same speed no matter if it has three grounds or one. I have to index the plugs to clear the domes much less two more grounds.I just thought I would ask.
The spark ONLY jumps the shortest gap... so its a JOKE that they jump 3 gaps at once... any multi ground is for longevity and thats all(just as long as the electrode doesnt burn faster than the 3 straps)
Re: e3 spark plugs
[Re: oldtimer5151]
#1110483
11/10/11 03:09 PM
11/10/11 03:09 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
Snake oil, I got some if you want to buy some There is no magic in car parts, usually According to a old time mechanic that raced on Muroc dry lakes back in the 1920 and 1930 before WW 2, he said that all the ideas had been developed before he started dry lake racing and any new invention was a repetion of those things already developed, that was in 1966 or so and I doubted him then I have discovered over the years he had a very valid point Not much new has been invented since the early 1900 on cars, motors and car parts There has been progress due to new materials, different ways of using the technoligys Progress is ongoing Some of the spark plugs in the old cars, Pre 1920, had multiple grong straps, same thing on airplane spark plus, massive, multiple ground elctrodes and the new tech.(1960 era development, I think ) mini Platunum ground wires in airplane spark plugs the picture is one of my old airplane Champion massive ground spark plugs, those plugs where first used in 1920 or 1930 in Lycoming air cooled 540 C.I. opposed six cylinder motors that had 8.5 to 1 compression and where limited(governed) to 2700 RPM max. this was with dual spark plugs per cylinders and independent dual magnetos The ground electrode will corrode over time, usually you can close them up several times before they become to worn(there is a FAA spec to use) to reset and reuse These are gapped at .016 and require regapping when they get to .019, some of the old timers on a budget gap theres at .014 and run them until they get to .020+ before regappingThe center ground electrode will wear and elomgate also, I don't know if you can see that elongation in this picture
Re: e3 spark plugs
[Re: Cab_Burge]
#1110484
11/10/11 03:21 PM
11/10/11 03:21 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
all that extra material on the ground strap just causes heat soak...and gets too hot on a performance engine.. it ends up heat soaked like a glow plug..and causes detonation
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
Re: e3 spark plugs
[Re: oldtimer5151]
#1110486
11/10/11 05:49 PM
11/10/11 05:49 PM
Posts: 20,662 in a cattle trailer down by th...
Guitar Jones
Snake oil is correct. There is technically nothing new under the sun.
Re: e3 spark plugs
[Re: Guitar Jones]
#1110487
11/11/11 08:59 AM
11/11/11 08:59 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Mr P Body, The cut back strap sparkplugs you use, are you getting them cut back ootb or are you cutting them back yourself? I tried to cut a set back but just ended up ruining a few sparkplugs before I just gave up on it and installed them the way they came. If there is a pre-cut strap plug, where ya getting them?
Dub
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
