Re: BOTTOM-END GIRDLE KIT???
[Re: smokinwoody]
#1109420
11/08/11 06:05 PM
11/08/11 06:05 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I think you do have to go to main studs which means you have to have it line bored on the mains.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1109421
11/08/11 07:55 PM
11/08/11 07:55 PM
Posts: 5,080 organ
maximum entropy
organ
imo, any girdle is a good idea on any bb mopar. i've installed a bunch of 'em from various suppliers- chenoweth, source, mancini, bcr. i prefer the drop in units. the bcr was a lot of work, as the machine shops in my area were unable to handle the machine work necessary. it is a very nice piece, but overkill in my estimation.
[Re: maximum entropy]
#1109422
11/08/11 08:31 PM
11/08/11 08:31 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
i use the one from mike at chenoweth,bolts right in
[Re: blracing]
#1109424
11/08/11 08:51 PM
11/08/11 08:51 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
the one i found is from chenoweth girdles. the phone # is 626-869-0270. it was on racing junk awhile back. i hope this helps!sorry i don't have anymore info! the price was 425.00.
thats CRE....yeah the studs and all the fastners come with it...be kinda expensive just for a metal plate...
[Re: nss guy]
#1109428
11/08/11 11:15 PM
11/08/11 11:15 PM
Posts: 4,590 Indy
joshking440
Lunch is on me!
Lunch is on me!
Indy
How much clearance between the oil pan and center drag link with the girdle installed?
it moves the pan down .550 if i remember correctly
[Re: Labratt]
#1109430
11/09/11 02:41 AM
11/09/11 02:41 AM
Posts: 1,600 Alberta Canada
StrokerAspen
Alberta Canada
Hey Randy.... When I am not making decals..... I am making engine girdles. want me to get a BB dodge girdle together to send down with the decals I am doing for you? -Kenny
[Re: joshking440]
#1109433
11/09/11 05:24 AM
11/09/11 05:24 AM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
if you are going to use a girdle, the only one worth buying is the bcr piece in my opinion.
Becareful of the type that use washers and spacers to make up the difference between the mains and the pan rail as those really dont do what you are looking to accomplish
Josh, what does the BRC one do that the others don't. I got one from Hughes on mine and it uses spacers and shims between the plate and the main studs.
Thanks, Brian Dunnigan
[Re: Labratt]
#1109437
11/09/11 12:02 PM
11/09/11 12:02 PM
BradH
... A few people have suggested that at my power level,I REALLY don't need one...
You're pretty close to the power level where I was seeing clear evidence of cap walking w/ only OEM caps and studs. Do you absolutely have to have something beyond that? No. Would it be a good idea to add some insurance? IMO, yes.
The CRE kit is nice (I have one that I haven't actually used, yet), but their competitors came out later w/ comparable products for less money. Hughes or whomever can provide you w/ a viable option, since IMO (again) the BCR approach ( ) is overkill for your application. As pointed out by others, if you don't have main studs installed in your current build, they do say you'll need to align hone everything w/ the new studs to ensure cap location.
